Like Tree352Likes
NOVAROSSI Engine thread....
Old 09-14-2014 | 07:44 AM
  #7126
I won some werks #5 plugs at race this past weekend. Are they the same as novarossi plugs if so which ones ? C5tgc ?
evolution03 is offline
Old 09-14-2014 | 12:53 PM
  #7127
Integra's Avatar
Originally Posted by Lille-bror
You make the tuning thing waaay too complicated sn47. Go out on the track with a skilled tuning person and learn from her/him.
+1
Idle is Moot on the box.
Track tuning is the ONLY way to ensure its proper and wont "wonder" once its fully up to temp.
Integra is offline
Old 09-15-2014 | 05:21 AM
  #7128
sn47som1's Avatar
Originally Posted by cczjordan
Basic tuning start with rich, get the idle right then fine tune. Idle gap can vary so listen to the engine sound.
Tips: .5mm/.6mm/.7mm/.8mm idle gap, you measured by special tools? So go with the sound/observation, dont let ppl fool you by saying bla... Bla... Bla
No buddy, certainly no one will fool me its not about that... Guys like Maximo from CRE a guy that knows more then all us about nitro engines is saying things like this so.....
Thats the point, JUST going by listening isnt enough to ensure having a balanced tune meaning a proper gap, lsn and hsn settings. If too high gap, to rich lsn that could be also masking a lean hsn, etc etc. I dont know about you but with my $550 engine it better tuned right. I used to think like all you guys (what ur saying) and I learned some more things, thats why i posted some of this info, to help us all maybe just listening which is obviously what I do as well, but then checked my carb 1 day and my gap was like almost 4mm! and i thought it was tuned pretty well. This means the lsn was prob too rich and high end too lean. Now how bad is an out of balance carb for the engine, i dont have real world proof for consiquences, but you i know that you can get the most out of the engine power and runtime wise if its set right. Hey by all means, if just going by listening all the time is it and makes no diff making sure its "in balance" and optimally set, then then better for us cuz that would be less work. Any other ideas would be good.
just remember Maximo isnt a fool wen coming to nitro, so just trying to help..
sn47som1 is offline
Old 09-15-2014 | 05:44 AM
  #7129
sn47som1's Avatar
Does anybody have a part number for the head button for a Nova Keep Off 7?
sn47som1 is offline
Old 09-15-2014 | 05:51 AM
  #7130
HomicidalBunny's Avatar
I don't think anyone called Neal a fool. But to think that you should tune with the air filter off so you can see the idle gap, you're getting finicky. I don't consider myself an experienced tuner, but I know that tuning with no air filter (regardless if you're in a controlled, clean environment or not) is a recipe for headaches. Just tune your engine off of how it reacts to what you're doing. You will get the best results if you listen and observe what your engine is doing. If you hear it bogging down, you dont take it into a sterilised green room with hazmat suits and make an adjustment there, you simply richen or lean the engine depending on what the smoke from the pipe, the sound, and the PERFORMANCE of the engine is telling you. As Paul and Cody King say, "you shouldn't settle for second-best". Now that doesn't mean you need to go all scientific and anal about it. Just do what you think is right, and go from there. I don't know what else I can say, but I cannot reiterate enough that it's taking it too far if you start to tune with the air filter off.
/rant
HomicidalBunny is offline
Old 09-15-2014 | 05:53 AM
  #7131
Looking at the exploded views of the Keep-Off 21.7XL, the part number you're looking for is 28025 (bare head button) and maybe 29002 (head button o-ring). The oring doesnt do much but add another layer of protection from dirt and dust.
Old 09-15-2014 | 07:00 AM
  #7132
sn47som1's Avatar
Ahh cool thanks buddy. My first thought was to look at the exploded view... I searched the net for the part first. Thanks anyway Ill look that part up. A side note, I wasnt saying anyone called Neal a fool, i was making a point thats all, food for thought.
sn47som1 is offline
Old 09-15-2014 | 08:30 AM
  #7133
Maximo's Avatar
I don't tune with the airfilter off......
However when I help someone tune I always remove the filter to check the idle gap and make sure the linkage is working correctly...You can't even imagine how many have their linkage set incorrectly with a false idle gap....So before I waste any time messing with needles I check the idle gap and make sure the linkage is not holding the slide open at neutral position.....
Maximo is offline
Old 09-15-2014 | 08:45 AM
  #7134
sn47som1's Avatar
No on esaid you did Neal. But you do talk about the carby being in balance for tuning and not being good having a needle being either too lean or rich by being masked from a poor setting of another needle, which could then mask another improper needle setting, like the carb being way out of wack but still running decent. So from that, I took it too why dont guys tune the low end/idle without a filter, so setting the gap visually and getting the pinch test down pat. Then moving forward with the rest of the tune on the ground? I hate tuning the low end cuz its always a mutliple stage process with the gap and needle... just trying to better that process. Then tune with filter and hsn on ground.
sn47som1 is offline
Old 09-15-2014 | 08:58 AM
  #7135
kgombe's Avatar
well for starters tuning any needle while the filter is off is not going to do you any good, because once you put the filter back on the the will change anyway.. so why even do it...
kgombe is offline
Old 09-15-2014 | 10:07 AM
  #7136
sn47som1's Avatar
Well there goes that idea then lol
Has anyone heard of or tried the JP Gimar mig21 Dirt 7? Looks like a bad arrrrse engine! Check em out on ebay. What do you think? Seems like peeps arent really running JP anymore in the US? You think there are better engines out there?
http://www.ebay.com/itm/JP-GIMAR-Rac...item4aa9b72519
sn47som1 is offline
Old 09-15-2014 | 10:18 AM
  #7137
The bottom line is that there is no magic setting for the idle gap. But, once you have it in the ballpark, only minor adjustments are necessary. If you have an engine with a 4mm idle gap that feels like it's "tuned pretty well", something is off with either the engine, clutch, or your perception of tune. In any case, you are better off getting some help from a fellow nitro racer, and save yourself a lot of headaches.
071crazy is offline
Old 09-15-2014 | 10:38 AM
  #7138
sn47som1's Avatar
I think i exaggertated a bit, it was probably more like 3mm at the most, but still you would say that there is a prop/correct setting for the gap right? I know there isnt magic involved lol but theres correct and incorrect settings follow?
sn47som1 is offline
Old 09-15-2014 | 10:39 AM
  #7139
sn47som1's Avatar
Anyway, I wish you guys were at my track some days...
How bout these Gimars?!
sn47som1 is offline
Old 09-15-2014 | 12:04 PM
  #7140
Maximo's Avatar
I do definitely support visually inspecting and even measuring the idle gap.. makes it easier to help someone tune when I know for sure their needles are where they are supposed to be...I have seen some tunes so jacked up that i would be needling for a week trying to get it sorted...So for me I always like to set a 0.5 mm idle gap and use that as a base to start from...gives me somewhat of a reference point if not anything else....
Maximo is offline
