NOVAROSSI Engine thread....
#7846
I m sure is long lsn. Only SOS will use short. A way to check it is by removing filter boot n wot, observe the lsn edle movement from jet area.
1. With 30%-50% throttle input, lsn pull out completely = short
2. With 90%-100% throttle input, lsn still/out = long
Short or long is easy to check, u never know? Wonder how u tune ur engine
#7855
So wanted to ask anyone know who has any P/S/R in stock for the P5? My P5XLT has lost its pinch, and would love to go with a new P/S/R but at the same time feel like I should just get a new P5XLT :/
Having been directed here...
#7856
amain has the p5 for $185. so probably just worth getting a new one. thats what i'm going to do.
#7857
#7858
#7859
Yes it has been. Which is why I thought next step would be a new PSR. But I will look at just a new motor, may be easier and less hassle.
Thanks for the help and links.
#7860
I would measure the crank pin before buying a new p/s/c, usually it wore out after hard running. If d crank pin NG, just it pinch n run it again. New engine is best solution
352Likes
