Like Tree352Likes
NOVAROSSI Engine thread....
Old 06-12-2015 | 10:58 AM
  #7861
sn47som1's Avatar
Originally Posted by cczjordan
I m sure is long lsn. Only SOS will use short. A way to check it is by removing filter boot n wot, observe the lsn edle movement from jet area.
1. With 30%-50% throttle input, lsn pull out completely = short
2. With 90%-100% throttle input, lsn still/out = long
Short or long is easy to check, u never know? Wonder how u tune ur engine
I tune the standard way. HSN first, then LSN and idle. Then I dial them all in for a final adjustment.
sn47som1 is offline
Old 06-12-2015 | 11:00 AM
  #7862
Maximo's Avatar
Originally Posted by sn47som1
Neal, can you elaborate on this engine more and make comparisons to previous higher port Novas? crank specs? Thanks
so what I see unique about this engine is that it has a powerband that peaks much earlier then most other offroad .21's, yet still manages to pull power all the way up to 40 000 RPM. At only 20 000 RPM this engine is already making full torque.. which will allow it to pull a lower clutch stall and give a better trigger feel.... It makes similar HP numbers to a OS Speed but peaks about 5000 RPM earlier which means it has much higher torque numbers...Also so far it is showing to be extremely good on fuel... I will offer it in a track tuned format that will operate best on a 41021 manifold using any of 2096,9886,9901 and 9853.....I Will also offer it as a modified... the track tuned will more or less retain the current powerband range, the modified will have the powerband moved up to 25 000 RPM....However with that being said the stock version is quite formidable , especially if you are after a engine with really good tractable grunt..it has lower port timings so the idle is very strong and the tuning quite stable..... All in all for the money its a really sweet engine....
Maximo is offline
Old 06-12-2015 | 06:11 PM
  #7863
sn47som1's Avatar
So then it sounds like the clocked keep 7 or bonito would be more beast with just as good fuel mileage?
sn47som1 is offline
Old 06-13-2015 | 07:57 AM
  #7864
cczjordan's Avatar
I'm curious to find out, breakin in a stock paloma 41021/2096 today. I think it is more suitable for truggy
cczjordan is offline
Old 06-13-2015 | 10:32 AM
  #7865
Maximo's Avatar
I Will not longer be using the moniker " Clocked " to describe my engines.....I am now The Nitro Shop...or TNS.....
SO yes my 7 ports are going to be more aggressive in the midrange and top end, have a more aggressive feel...The 8 port is going to have more grunt and more of a 4 stroke feel to it.. So depends what your are after,,,drag racing down the straight or popping huge air off short run jumps...
Maximo is offline
Old 06-13-2015 | 12:03 PM
  #7866
Suspended
Anyone with experience with the Top Elite 5? How does it compare to say, the P5?
Socket is offline
Old 06-13-2015 | 02:39 PM
  #7867
sn47som1's Avatar
I'm after it ALL- run up grunt and "the drag race" characteristics/powerband and very good mileage all in the same engine. SO which TNS modified .21 would you recommend for this? Thanks Neal
sn47som1 is offline
Old 06-13-2015 | 03:18 PM
  #7868
sn47som1's Avatar
Let us know how it goes compared to other 7 portys. I heard its beast.
sn47som1 is offline
Old 06-13-2015 | 06:26 PM
  #7869
cczjordan's Avatar
I'd seen a bonito run, i willl say close. Small track/low traction imo will need to restrict its power. With the price, sure is a bargain
Old 06-13-2015 | 08:04 PM
  #7870
mallee RC's Avatar
Default Elite 5
Hi mate, I have had Neils TNS Elite 5 for only a short period, I have also had the stock P5, with comparison, the Elite 5 has loads More bottom end power, still has a great top end, however imo its a truggy engine with a bottom end that's required with truggy! It has a extreme Bottom End compared to the P5. Checkout Neils Dyno results on his facebook page, they are awesome results! Good value for money engine, keep in mind, break in off ANY engine, is the key to a quality engine that performs well- DONT RUSH IT !
mallee RC is offline
Old 06-14-2015 | 10:46 AM
  #7871
bash bros's Avatar
Does anyone use the Avid ceramic bearings in their engines?
I kinda want to try them in one of my p5xlt's. They are a hell of a lot cheaper than the Novarossi branded bearings.
bash bros is offline
Old 06-14-2015 | 01:09 PM
  #7872
Jerm13's Avatar
Not Avid's but TKO's. Had a couple that I replaced at about 8 gallons just cause. Matter of fact, got the stock Nova double seal up front and TKO Ceramic in the rear of my P5 now. Been like that from break-in.
But I have had real good luck with the Avids in other parts of all my cars...I wouldn't have any reserves about running them in my engine. And deffinetly a ton cheaper than the Nova bearings...
Jerm13 is offline
Old 06-15-2015 | 12:15 AM
  #7873
cczjordan's Avatar
Can any gurus pointed out what is the difference between this 2, i can not tell difference in term of performance
TN Team vs bonito/keep off sleeve porting
Old 06-15-2015 | 10:53 PM
  #7874
Default Pipe suggestion for p5
Hey guys I got a ? What pipe do u recommend for a p5 with the 15007 crank ? It's for a Losi truggy I ran the 9901 and it feels ok . So just need yalls input I'm trying to decide what pipe to buy next for this p5 . Thanks guys
Artlosi is offline
Old 06-16-2015 | 12:23 AM
  #7875
shannow's Avatar
Hello, my p5xlt has almost reached 15liters of use so I decided to have a go at cleaning it internally. Inside the engine it was very dirty. Sort of a crust very black everywhere inside the chamber exept the cylinder wall of course. The head of the piston ans cylinder head were the worst. Is it normal after 15L?
shannow is offline
