Like Tree352Likes
NOVAROSSI Engine thread....
Old 01-27-2014 | 10:05 AM
  #6361
Originally Posted by jccj816
I have a Truggy running Beat 4 engine with 9901 pipe and 41021 header. Would 2096 pipe with 41021 header be any different?
Yes, 2096 would have less bottom end and more top end.
Maybe you'd want to try 41005.
Eivind E is offline
Old 01-27-2014 | 10:18 AM
  #6362
beidle99's Avatar
If I remember correctly the beat 4 is similar if not the same as a plus 4 btt, its not really a truggy engine. I would say run the 53 pipe and 41021 header if you have your heart set on running the beat 4 in truggy.
beidle99 is offline
Old 01-27-2014 | 10:22 AM
  #6363
No, it has the same sleeve as 21-4C afaik. Slightly different exhaust port.
Eivind E is offline
Old 01-27-2014 | 11:16 AM
  #6364
am
BTT has a wider exhaustport. It will have a larger area and use a bit more fuel. It will also have slightly higher rpm.
am is offline
Old 01-27-2014 | 02:58 PM
  #6365
kgombe's Avatar
Having ran that engine in my truggy, i will tell you from experience that if you have short run ups to jumps you will definitely miss the 9901, for the most part the 9901 is better than the 2096 for that engine in truck, or you can try the 9853 which is awesome.
kgombe is offline
Old 01-27-2014 | 04:20 PM
  #6366
Default Need Assistance
I have an old Novarossi 2001BF .21 engine. Runs great. But I am looking to or wanting to convert it from a standard plug to a Turbo plug.
Will a P5 or P5xl turbo button work on this motor ?
If so what else will I need to do to make sure I am not damaging the motor?
RevoUsa is offline
Old 01-28-2014 | 05:27 AM
  #6367
This is our track. Not much of a high speed track, recorded fastest lap time is 37 sec. We use P5 and Plus 4 with 9901 pipe.
Will a KeepOff 4 port suffice or should we consider a 7 port? I know the 7 port is more high tech. I also race occassionally at PRC track, Pattaya-Thailand.
My track buddies have been pushing me towards OS, but hearing mixed reviews. Hope I will not regret the Nova purchase.
rcindia is offline
Old 01-28-2014 | 09:34 AM
  #6368
SEF's Avatar
SEF
After trying several different engines, I now only use OS and Nova engines. I have about a gallon on my keep off 4 and so far I love it. Very usable powerband and good runtime. I race on two tracks where the fast lap is around 31 seconds for one track and 37 seconds for the other, and the keep off is plenty of engine for buggy.
Drake races at both tracks all the time and is using a keep off 4 with the new carb. He says the new carb makes the low end more crisp and gives a little bit more all around torque to the engine, but no significant increase or decrease in runtime.
SEF is offline
Old 01-29-2014 | 05:59 AM
  #6369
aussies1129's Avatar
Looking at the new off-road line up for 2014 can someone explain what the different carbs offer? Looking at the new p5 there's three carbs available?
aussies1129 is offline
Old 01-29-2014 | 06:30 AM
  #6370
dhopkins8's Avatar
The Clio looks interesting!
Looks like they are using the +4C crank and team piston like the BTTA, new head and button, and the new carb.
Can anyone chime in with a price? Do you think they will still be valued somewhere around 200-225? I hope so!
dhopkins8 is offline
Old 01-29-2014 | 08:44 AM
  #6371
No, if you look at this: http://www.novarossi.it/2012/images/...va/CLIO-P5.pdf
You will see it has 15009T crank, so that's not what's in the +4C.. team piston, yes..
So basicly this is a Maxy's cinco, but in Novarossi branding, but with the new carb.
I think it should be a nice little engine, and I'd be wanting one if the price is right
Eivind E is offline
Old 01-29-2014 | 09:38 AM
  #6372
kgombe's Avatar
may not be plus 4C, but it is from a plus 4 buggy.. the one just before the C
kgombe is offline
Old 01-30-2014 | 06:15 PM
  #6373
beidle99's Avatar
And the exterior of the engine case looks very familiar to another engine I have.
beidle99 is offline
Old 01-31-2014 | 01:11 AM
  #6374
The CLEO will have a street price of $300-325. If you want a $200-225 engine the P5XLT will continue to be available in the USA.
desotoracing is offline
Old 01-31-2014 | 05:23 AM
  #6375
banana rt's Avatar
any review for Clio, how its tuned and performance.
banana rt is offline
