NOVAROSSI Engine thread....
#6393
I ran a BT4 engine with 9901 and 41021 at a race recently and it seemed to do fine. I could get 11 minutes a tank. I'm looking for more bottom end. I guess I'll try the P5 engine with 41005 and 9901
#6394
So that's why I think you'll get more pull with 41005 and 9901 with the p5.
#6399
#6402
2. are you sure the head shims aren't just hiding out, playing chameleon? Sometimes they get stuck on there and are hard to spot.
#6403
-The HSN is deleted and now there's a middle range needle will be used as a HSN, the usual LSN and the idle. The new carb gives more power, runtime and a better idle. Carb is very easy to tune.
-The virtus has a little more power than the 4Team and is way more aggressive.
-The virtus has a 2mm carb offset to enhance mixture flow and be a stable running engine.
Hope it helps.
352Likes
