Like Tree352Likes
NOVAROSSI Engine thread....
Old 06-06-2015 | 09:16 PM
  #7816
sn47som1's Avatar
Hey guys, at the moment my Nova Keep Off 7 has 2 silver ( I think each is .2mm) head shims, so a total of .4mm head shim thickness. Can I remove one to test for power and performance changes? - Thank you!
sn47som1 is offline
Old 06-07-2015 | 12:04 AM
  #7817
cczjordan's Avatar
Not sure bout d keep off but depends on the % of nitro u using, if nova c6 shouldn't be a problem.
Some taiwanese motor love higher compression ratio, not sure bout nova
cczjordan is offline
Old 06-07-2015 | 03:23 AM
  #7818
beidle99's Avatar
I dont know about the Keep off engines, but Nova's typically come with .8mm shimming and after a few gallons you can remove a .2mm and add a .1mm to get to .7mm. Chances are you are missing something, or the brass shim is stuck to the head button.
beidle99 is offline
Old 06-07-2015 | 12:31 PM
  #7819
Originally Posted by kgombe
Actually they say its shimmed for 25%, maybe they can't use no higher than 25% across the pond?
just checked a manual here and the recommended fuel is 25%
My understanding was the .8 shimming is good for 30%, and .7 is just right for 25%.
Hence why I thought they came shimmed for 30. IF they now come shimmed for 25 (.7) then that would be different.
Eivind E is offline
Old 06-07-2015 | 01:18 PM
  #7820
rallyebmx's Avatar
I have a brand new keep off 4 crank shaft that I sent to Lance at RcRenew to be silicone filled. Never used, never installed. Pm me if interested
rallyebmx is offline
Old 06-07-2015 | 05:04 PM
  #7821
sn47som1's Avatar
Thats the thing, there is no brass shim. ONLY 2 silvers. I would like to remove one. Wats the worst that could happen? pre detonation? It actually sounds like then Im already running a high compression ratio with .4mm which is what I was thinking, but Id like to raise it more....
sn47som1 is offline
Old 06-07-2015 | 05:14 PM
  #7822
sn47som1's Avatar
Actually to be honest Im just assuming they are .2 because I thought all silvers were .2 but maybe they are thicker like .3 or .4mm shims each making a total of .6 or .8mm.... I cant measure them at the moment
sn47som1 is offline
Old 06-07-2015 | 06:17 PM
  #7823
kgombe's Avatar
the silver shims are .3
kgombe is offline
Old 06-07-2015 | 06:18 PM
  #7824
merdith6's Avatar
Default well
The copper shim may be sandwiched between the 2 .30 shims.
The stock setup is 2 .30 silver shims and one .20 copper or brass shim for a total of .80.
merdith6 is offline
Old 06-07-2015 | 07:24 PM
  #7825
sn47som1's Avatar
Thanks so much guys! Cool, so now I know I'm running a .6mm stack. Have any of you run .3mm?
sn47som1 is offline
Old 06-07-2015 | 07:29 PM
  #7826
pballer2777's Avatar
i have a plus 4 that has just about had it. i love the engine, but its time to move on. whats the closest engine to it currently? i love the fact of how smooth it is in my buggy and would like to get the same from my next mill.
pballer2777 is offline
Old 06-07-2015 | 08:39 PM
  #7827
houston's Avatar
plus 21-4btts?
lmk if you are looking for one
new engines are drnt bore x stroke , the mito4
houston is offline
Old 06-07-2015 | 08:41 PM
  #7828
houston's Avatar
piston will hit the squish band on head button , engine will be toast
houston is offline
Old 06-08-2015 | 02:50 PM
  #7829
sn47som1's Avatar
Thanks Monty! looks like ill be leaving it alone lol
sn47som1 is offline
Old 06-08-2015 | 02:56 PM
  #7830
sn47som1's Avatar
I saw a Mito 4 run a few weeks ago. It was so linear and smooth all the way from bottom to top. Im sure you wouldn't be disappointed at all. The guy running it claimed he was getting over 11 and 1/2 mins run time too :0 Could have been a crazy small venturi he was running.... idk
sn47som1 is offline
