NOVAROSSI Engine thread....
#8566
Im just getting back in to nitro.. I just ordered a Mitto 4,2096 pipe ,and 021 header for my RC8B3. I'm really looking forward to running this. I ran nitro a few years back but only for a few months. I've been running 10th scale in the mean time. Any recomendations or tips are welcome.
#8568
Its pretty much the P5 with a LCG head and newer 3 needle carb. pipe depends on what you want the motor to do for you. Torque, 9901, smoothness, 2096 or all out RPM 9886.
#8569
Imo 2096, smooth n higher top, 9901 for no reason will max out pretty soon, small track maybe suitable
#8570
9901 can scream like a banshee once you put on the 41001 manifold.....its a dud on the 41021
41001 manifold makes a huge amount more power then a 41021, pretty much on every engine but one the 41001 substantially outperforms the 41021
#8573
#8575
Just to add...9886 also makes more torque then both the 9901 and 2096...... 9886 has the most power from idle to top end... the 2096 has the identical power curve as a 9886 except it has about 20% less power across the entire RPM range......
#8578
9901 pipe with 41021 header
2058 pipe combos
some other pipe combo as well.
#8579
Just got my Paloma Limited today. Thought I'd share the exploded diagram since there is next to nothing out there for info on this engine. The specs the have listed on nova-direct are incorrect, they have it mixed up with the regular blue paloma. Anyway... kinda hard to see but..
89005 Crank- Looks alot like a 15007 or 15009
16800 rear bearing
06000 Microcast piston & 7 port sleeve
07009 Conrod
24069 Carb
The only thing I was real bummed about was the front bearing is a 17004, but for $129 I guess I can't complain. I have an extra 17011 so I'll probably just swap it out for that.
16800 rear bearing
07009 Conrod
24069 Carb
#8580
16800 rear bearing
07009 Conrod
24069 Carb
16800 rear bearing
07009 Conrod
24069 Carb
352Likes
I was so close..
