Like Tree352Likes
NOVAROSSI Engine thread....
Old 11-28-2018 | 08:34 AM
  #10066
savage24x's Avatar
Originally Posted by savage24x
My Paloma has an idle issue that I can't seem to figure out. It'll start no matter what somewhat high with the wheels spinning... then about 45-60 seconds in they'll stop spinning and I let it warm up to operating temp. After I'm at operating temp (at least 220F), I can give it any kind of throttle and let it go back to idle, which it'll then idle high for 15-20 seconds, then go down to it's normal idle. It's somewhat common from the searches I've done, but I can't lean the LSN any further. I can find the perfect point for my LSN before it starts lean bogging on bottom end... Should I be leaning out the top end and then going from there?
This engine holds a tune so dang well, it starts within a second every. single. time. Stays running, too, even with a bad tune.
41001/9886 combo, #6 plug, 8mm carb insert. Fresh air filter. 25/9 VP fuel.
Still having this problem... any suggestions? End points are correct. Carb fully closed and fully open. Tune does not change on brake.
savage24x is offline
Old 11-28-2018 | 09:07 AM
  #10067
My internet guess would be your hsn is a bit lean. When you close your throttle it revs high as if it’s lean, but then settles down once it’s been running on the LSN.
savage24x likes this.
Micah78 is offline
Old 11-28-2018 | 10:05 AM
  #10068
timjs's Avatar
I agree. Sounds like lean HSN for sure, likely also with an overly rich LSN to compensate.
Micah78 and savage24x like this.
timjs is offline
Old 11-28-2018 | 01:01 PM
  #10069
Exactly! I’ve been there many times.
Micah78 is offline
Old 11-28-2018 | 01:09 PM
  #10070
houston's Avatar
CLEAN OUT HSN .... then reset HSN to 4 turns from closed ..... adjust LSN and idle gap while HSN is still a bit rich ..... then lean HSN until desired runout
airleak?
sometimes you just need to start at a base setting
5 turns from full closed on LSN 4 turns from closed on HSN
be sure to pull linkage open before running LSN in
savage24x and Anunnaki like this.
houston is offline
Old 12-07-2018 | 05:38 PM
  #10071
Bugman's Avatar
Have any of you guy,s ran the mephisto yet just curious to hear any feedback.
Bugman is offline
Old 12-07-2018 | 07:29 PM
  #10072
pballer2777's Avatar
jack im thinking about getting one of these also.
CedarCityJohnny and Anunnaki like this.
pballer2777 is offline
Old 12-08-2018 | 05:08 AM
  #10073
OH YEAH !!!!!!!!!
Anunnaki likes this.
bkuff-losi is offline
Old 12-08-2018 | 09:23 AM
  #10074
According to the Novarossi website the Mephisto is a Mantra with a different crank and carb, so unless they did some changes to the crank besides DLC it should run the same.
NitroVein is offline
Old 12-09-2018 | 04:37 AM
  #10075
So you mean that the Mephisto is a little evolution of the Mantra?
Is Mephisto better in terms of fuel consumption versus Mantra?
Pedro Jesus is offline
Old 12-09-2018 | 08:50 AM
  #10076
I have no idea, I haven't used the Mephisto, just pointing out the possible difference if there is any.
Old 12-11-2018 | 05:47 PM
  #10077
J.Whiting's Avatar
Super Moderator
From: a very small town in wisconsin that is in the middle of absolutely no where
they made the crank a tick bigger per novas site. different glow plugs. different carb. 3 needle like the rolling. and better cooling head and they say different exhaust to use.. I can give more on this when it shows up Friday and I can put the 2 motors side by side.. jeremy
Pedro Jesus and Anunnaki like this.
J.Whiting is offline
Old 12-12-2018 | 10:33 AM
  #10078
I was looking at the mantra for awhile but got mephisto when they came out, Drake has it now doing the break-in. The BTT square stroke was my favorite buggy motor ever, so I'm hoping this is similar
RePeTe is offline
Old 12-12-2018 | 10:48 AM
  #10079
They both say they have a bigger crank bore, and though glow plug isn't exactly engine specification it is the same on the exploded view.
The only thing that make any real difference is if they have changed the crank in timing or bore etc, all the rest is the same between them. The carb could have slight difference in how it feels and tunes, but not in power.
But measure the timing and get back to us.
Old 12-16-2018 | 09:24 AM
  #10080
I have an elite 5 paired with a 41021, and a 2096 pipe. I have about a gallon and a half on it. It is a great motor but I am looking to get a little more power. Would changing pipes help in yhis, or should I attempt to remove a shim?
DXPinoyRC likes this.
xpertpredator is offline
