Like Tree352Likes
NOVAROSSI Engine thread....
Old 12-19-2018 | 04:51 PM
  #10096
J.Whiting's Avatar
Super Moderator
From: a very small town in wisconsin that is in the middle of absolutely no where
Originally Posted by NitroVein
So did you compare timing on them?
i have not yet.. break it in as I have a race in a few weeks and very limited time to get it ready.. actually im breaking it in as I type this.. the 2135 pipe is nice tho.. in between the 9901 and 9853.. has a nice sound to it.. the tear drop design head looks pretty nice also..
Pedro Jesus, jersey and Anunnaki like this.
J.Whiting is offline
Old 12-21-2018 | 03:40 PM
  #10097
Cain's Avatar
Tech Legend
hey everyone, I got in a package deal that came with some of the Odonnell 267T mileage plugs. I am wondering if these can be used in the .21 Paloma limited engine?
Cain is offline
Old 12-24-2018 | 02:44 PM
  #10098
J.Whiting's Avatar
Super Moderator
on the mephisto the crank does not have silicone in it.. might be a nice added feature. got a bunch of running in on it and found the 41021 header and 51007/2135 to be the best for tune.. the 41021 header and 9901 pipe was about the same but needed to be 1-2 hours richer on top and 2-3 richer on the top to have same temp and idle/clear out on top end.. power band felt pretty close to the same for the testing we where doing..
Pedro Jesus and Anunnaki like this.
Old 12-26-2018 | 02:29 PM
  #10099
am
Could you make a test with 2096 and 41005/41001 header?
am is offline
Old 12-26-2018 | 08:41 PM
  #10100
mercfocus's Avatar
Looks like it's a turbo plug and the Paloma has the turbo head button so it will fit.
I tried the Odonnel 97Ts in a couple of my Nova Rossis for a while but I didn't like them as much as the Nova plugs.
I'm kinda curious how your plugs will work out.
How about trying it and update us?
mercfocus is offline
Old 12-29-2018 | 03:11 PM
  #10101
J.Whiting's Avatar
Super Moderator
next weekend I will test those combinations out.. its 22* and snowing out here in wi usa.. but a long 7 hour drive next week to test for 2-3 days and will have a better answer also..
on plugs I have been using the gsr p5 plugs and in the really cold temps the gsr p4.. basically os plugs.. the gsr 5 is pretty close to the ct06 nova plug but half the cost
Old 12-30-2018 | 10:34 AM
  #10102
timjs's Avatar
Hey guys, I've got a fairly basic question (hopefully).
Couldn't quite figure it out with Google.
The 28-7 and 28-8 are both available with a rotostart option (for a Savage MT) BUT what the heck is the difference between them aside from port count? Thanks in advance.
timjs is offline
Old 12-30-2018 | 10:39 PM
  #10103
HaulinBass's Avatar
monty will have my mehisto right away ill see if i can get the numbers once he has it.
well scratch that I guess nova direct USA refuses to ship to monty and talked crap about him in the process, not very cool.
DXPinoyRC likes this.
HaulinBass is offline
Old 01-07-2019 | 09:15 AM
  #10104
Storing a 2 gallon engine to have as a backup, besides After Run Oil, and capping the exhaust and carb. Anything else?
sebtarta is offline
Old 01-07-2019 | 05:42 PM
  #10105
Suspended
Picked up a ls5 which im told is basically a p5xlt.
what pipe should i be using for just a allround pipe?
iplaygames is offline
Old 01-08-2019 | 04:17 AM
  #10106
41021 & 51006M (EFRA9901)
Pedro Jesus is offline
Old 01-08-2019 | 07:59 AM
  #10107
Default Tuning a novarossi
Ok after reading page after page on engines and tuning i think im even more confused. I read that novarossi motors tune different? How so? I also have a 2 stage idle but motor runs pretty good is that just how these engines run? P5xlt 9901 40210 ct06 plug 30% byrons
jbucao671 is offline
Old 01-08-2019 | 10:13 AM
  #10108
If you have a 2 stage idle the bottom end is not lean enough.
Chris Reilly is offline
Old 01-08-2019 | 12:32 PM
  #10109
houston's Avatar
watch this .... it should help
Chad Millikan and Anunnaki like this.
houston is offline
Old 01-08-2019 | 03:57 PM
  #10110
That is exactly what i was looking for! Just have to get on the track to tune the top end. So with novarossi tune bottom end first then the top on track? I still think my idle can close a bit more its 1 turn from closed looking down the carb. Temp was about 240/245 running in my yard witch is pretty much sand/dirt.
