Like Tree352Likes
NOVAROSSI Engine thread....
Old 04-24-2019 | 03:35 AM
  #10246
Roelof's Avatar
From what I remember from the past is that people had issues to tune or (re)start engines with an aluminum carb. A plastic carb did solve that. And yes, heat in metals make them expand and that could have influence on the precise tuning some engines need,
Winner's Circle likes this.
Roelof is offline
Old 04-26-2019 | 04:51 PM
  #10247
sn47som1's Avatar
Can you please recommend a throttle return spring for me or throttle bands that work well to close the Novarossi carb manually in case of servo or power failure? The usual hair bands Monty recommends ALWAYS break on me even if doubled up. Thank you
sn47som1 is offline
Old 04-27-2019 | 12:31 AM
  #10248
Chad Millikan's Avatar
There'sa couple that I have that work great. Dynamite RC makes one, Novarossi direct has some too
Throttle Return Spring
Dynamite RC Return Spring
sn47som1 likes this.
Chad Millikan is offline
Old 04-29-2019 | 07:41 AM
  #10249
Anyone have any ideas on how to remove seriously stuck head bolts? Previous owner used red loctite and 3 are impossible to get out and one is completely stripped. Any idea on how to get the 3 out and get the stripped one out? I’ve tried smacking the end of the screwdriver to try and loosen them and also tried heating up the head with no luck.
harawong is offline
Old 04-29-2019 | 09:19 AM
  #10250
Roelof's Avatar
heating up....
Roelof is offline
Old 04-29-2019 | 09:42 AM
  #10251
Heat gun will break away red locktite
wichitafc98 is offline
Old 04-29-2019 | 09:56 AM
  #10252
timjs's Avatar
Set oven to 300. Bake 10-15 mins until golden brown.
To get the stripped screw, try tapping in a Torx. Theres usually a Torx size that works great to grabbing stripped hexes.
timjs is offline
Old 05-01-2019 | 04:13 AM
  #10253
Do they still make replacement piston and sleeves for the 21-7 fms? Thanks in advance.
harawong is offline
Old 05-01-2019 | 01:49 PM
  #10254
anyone know what size bearings in the Novarossi 28-8?
I am assuming sealed bearings are the way to go in a nitro engine?
I want to have an extra set of bearings just incase.
Thank you.
Never mind: found the answer on the Italian Novarossi website.
GripTLR is offline
Old 05-01-2019 | 10:59 PM
  #10255
Stealthwave888's Avatar
Hey guys im looking at a handfull of brands inc the novarossi mephisto 4port 21 buggy engine..
any one used this engine and what was your experience?
bottom , mid , top end.. Etc
idle , holds tune... Etc
thanks in advabce.
CedarCityJohnny likes this.
Stealthwave888 is offline
Old 05-02-2019 | 06:33 PM
  #10256
J.Whiting's Avatar
Super Moderator
From: a very small town in wisconsin that is in the middle of absolutely no where
thanks in advabce.
its a lot like the mantra motor.. good all over engine for buggy. 2135 pipe and 41021 for header is what ive ran. seems to do everything right in my eyes. no issues with mine at all but only had my novas since December..
Stealthwave888 likes this.
J.Whiting is offline
Old 05-02-2019 | 07:33 PM
  #10257
thanks so much , appreciate the input , what about rear and front bearings.. Do you really replace them much? seeing as their not cheap.. Ie 86 a pop...
Old 05-02-2019 | 10:56 PM
  #10258
Roelof's Avatar
I can not tell for the offroad but with their onroad engines I do not need to replace front bearings very much. It is a standard size so you can find many cheap alternitives
Roelof is offline
Old 05-03-2019 | 03:04 AM
  #10259
thanks roelof
Old 05-03-2019 | 07:34 AM
  #10260
HaulinBass's Avatar
Nova hasn't used those bearings in several years the rear bearing is a standard 25.8x14x6 the front bearing is the same as the 17011 but with an extra ball
HaulinBass is offline
