Like Tree352Likes
NOVAROSSI Engine thread....
Old 05-03-2019 | 09:53 AM
  #10261
J.Whiting's Avatar
Super Moderator
From: a very small town in wisconsin that is in the middle of absolutely no where
Originally Posted by Stealthwave888
thanks roelof
the rolling. the mantra and mephisto all have different bearings.. I cant remember what bearings are in each but out of the 3 motors you need 4 bearings to cover the front and rear on all the 3 engines. but yes they are kind of pricy but ebay is a good source.. I have replaced 2 bearings in the 3 motors total and technically 1 bearing was in a buddies px5..
J.Whiting is offline
Old 05-04-2019 | 10:45 PM
  #10262
Stealthwave888's Avatar
thank you J.
Id appreciate if anyone has a good starting point for tuning in the mephisto as the deal on these are pretty awesome with nova clutch , complete pipe set.
Settings from flush.. Etc.
Stealthwave888 is offline
Old 05-05-2019 | 10:03 AM
  #10263
J.Whiting's Avatar
Super Moderator
thank you J.
hsn is flush
lsn is about a 1/2 turn out from flush
grs gs4 plug.. os knock off.
41021 header
cod. 51007 or efra 2135 pipe
220-240 range for temps.
Old 05-05-2019 | 10:28 AM
  #10264
The Rolling has 14.5mm crank and therefor uses a different rear bearing, but otherwise there isn't any difference in what fits between the three.
NitroVein is offline
Old 05-05-2019 | 10:39 AM
  #10265
hsn is flush
41021 header
why an OS plug? nova plugs work fine
RePeTe is offline
Old 05-05-2019 | 10:41 AM
  #10266
J.Whiting's Avatar
Super Moderator
hate to say it but wrong..
mantra front. 17011 rear 16801
mespisto front 17007 rear 16801
rolling front 17011 rear 16005
those are the bearing numbers. as stated before they semi cross over but 4 bearings needed for 3 motors.
Old 05-05-2019 | 12:45 PM
  #10267
HaulinBass's Avatar
17007 is the same size as the 17011 it just has black shields and 8 balls instead of 7. nova used it on the .28s around 2010
HaulinBass is offline
Old 05-05-2019 | 12:52 PM
  #10268
J.Whiting's Avatar
Super Moderator
novarossi site says
17007 is 7x19x6mm 7 ball
17011 is 7x19x6.3mm 8 ball
ya not much different but is not the same bearing.. at least for me to make sure I have both sizes
Old 05-05-2019 | 01:11 PM
  #10269
novarossi site says
There is no difference that matters, at all. And you don't need to run Novarossi bearings if you don't want to spend the money.
Old 05-05-2019 | 06:52 PM
  #10270
Thanks for all the input everyone makes it all the easier to enjoy running novarossi for the first time.. ,
and what is the race tune on the mephisto ?appreciated thanks guys.
Ill look out for quality bearings for the engine dont want to risk it other wise..
Old 05-06-2019 | 04:10 AM
  #10271
Both Avid and TKO has good bearings that's used by many.
https://www.avidrc.com/
https://tkocompetitiondev.com/
Old 05-06-2019 | 09:27 PM
  #10272
banana rt's Avatar
TKO is a great replacement bearing,
banana rt is offline
Old 05-07-2019 | 07:13 AM
  #10273
ZEe_NYC's Avatar
I have a RB motor that I just acquired. It’s a 9 port Rally Xtreme. Was sitting for a few months with what I’m assuming was fuel inside the motor. I took it apart and lubed it with after run oil and cleaned up anything I could. Put it back together and can’t get it to turn over at all. Took it apart a second time and heated it up in the over (at home) and it freed the motor up a bit where it now turns by hand (with flywheel on; but still tight at tdc. Rest of the movement is free. Bearings are good and free). The sleeve/piston has a weird click/thump at TDC. Pinch is tight, but seems off to me. Next move it to try a heat gun to get it to temp to attempt to get it turning on the starter box. I’m using an older 1/8th scale ofna blue top starter with lead gel battery that’s fully charged. I’m no pro, but I’m no beginner to nitro motors either.
Also trying to identify some parts on this motor. There’s an engraved ‘R2’ in a few places. Any clue who’s signature that is? also... replacement piston/sleeve/rod for this motor? Can’t find anything on Nova site. Not sure if nova internals are interchangeable.
ZEe_NYC is offline
Old 05-07-2019 | 07:15 AM
  #10274
ZEe_NYC's Avatar
sn47som1 likes this.
ZEe_NYC is offline
Old 05-07-2019 | 07:28 AM
  #10275
appreciated thank you , found that plaigbearings have some great bearings too
