Like Tree352Likes
NOVAROSSI Engine thread....
Old 06-12-2017 | 03:35 PM
  #9511
lilstewie's Avatar
Originally Posted by Maximo
9901 has crazy top end when its used with the right manifold ! your issue is you simply used the 41021 and called it a day...swap to a 41001 and that 9901 will put a big hurting on a 2096 ....the 9901 has a crazy good top end when it has the right manifold ! it just doesn't like the 41021, that manifold murders its top end
Would you run the 9901/41001 on the truggy as well with a 7 port?
lilstewie is offline
Old 06-12-2017 | 06:32 PM
  #9512
Jerm13's Avatar
That's what I'm running. Woke the motor up. Truck was good before, but that combo just made everything better. More speed, same torque, better run time and it feels a little more linier as well.
Jerm13 is offline
Old 06-13-2017 | 07:37 AM
  #9513
jazjato's Avatar
Thanks for the replies. Will have to do some more swaps and runs.
Has anyone put together a chart of pipe and manifild combos or uses?
Finding just reading novas description does not always help.
jazjato is offline
Old 06-13-2017 | 08:59 AM
  #9514
Novarossi Mito7 Is no longer available on the Novarossi website.
What happened? Low sales...
Yes it is not worth having a product in production that is not sold.
Pedro Jesus is offline
Old 06-13-2017 | 12:53 PM
  #9515
am
Just stay tuned..;-)
am is offline
Old 06-13-2017 | 03:23 PM
  #9516
joey91473's Avatar
Originally Posted by cczjordan
Thank you, what nova pipe do you run mostly, honestly i never like 9901
I only use the 9901 and 2086 pipe with 41001 header.
joey91473 is offline
Old 06-13-2017 | 09:22 PM
  #9517
Stu NZ's Avatar
Default On Road 2015
I have heard that the on-road novarossi 2015 pipe is good to use on a roma .25 .. is this just for fuel economy or a good all-round option..
Stu NZ is offline
Old 06-21-2017 | 08:35 AM
  #9518
Goof's Avatar
These flat head screws r garbage is there a hex screw opiton for the back plate and the cooling head
Goof is offline
Old 06-21-2017 | 09:11 AM
  #9519
dan_vector's Avatar
That seems strange to me as the 2015 is an onroad pipe which will give lots of RPM but reduced bottom end feel. On the ROMA in truggy I run 2096/41032 and this gives great power and runtime. The power band is quite linear with the 2096. If you want even more power then 9901/41032 but this makes the power band very aggressive in my experience.
dan_vector is offline
Old 06-21-2017 | 09:13 AM
  #9520
dan_vector's Avatar
Never had an issue with the flat head screws on Novarossi engines (never heard any complaints in all the years I've ran novarossi engines). What exactly in your opinion makes the screws garbage?
As long as you are using the right size screwdriver the screws are absolutely fine. Novarossi don't do optional hex screws but I'm sure you can find equivalent thread at the hardware store.
Old 06-21-2017 | 09:40 AM
  #9521
Goof's Avatar
Well yes i have tons of mac, craftsman, and a few others ... flathead it self are not good isnt that why we use hex or Phillips or star tip these days i love my nova enigens.. what screw driver are u useing there braking my tips off or rounding the edges off on the screws i need to change my front bearing lol crappy thanks for the help.. i even headed it up with my heat gun still wont brake loose
Goof is offline
Old 06-21-2017 | 10:18 AM
  #9522
Goof's Avatar
Its a issue for sure i took my dremel tool and shave the side of a biger driver and it work for some but by now the screws r gone
Goof is offline
Old 06-21-2017 | 10:59 AM
  #9523
snap on that fits properly.
Chris Reilly is offline
Old 06-21-2017 | 11:00 AM
  #9524
Apco1's Avatar
I'm with Dan. I did have the opinion the flat head were junk. Then I got the right size flat head bit and have had 0 issues. Like anything you have to have bit with zero play. Put the wrong size hex driver in a hex screw and see how well it works. Same with flat head.
Apco1 is offline
Old 06-21-2017 | 11:01 AM
  #9525
Apco1's Avatar
Get this and strip no more.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Apco1 is offline
