Like Tree352Likes
NOVAROSSI Engine thread....
Old 06-25-2017 | 05:46 PM
  #9541
mourinho's Avatar
big b - its either a 7 or 8mm open end spanner.
mourinho is offline
Old 06-29-2017 | 10:40 AM
  #9542
The NEW Novarossi
Novarossi, after months of testing, is pleased to present the new high performance 1/8th off-road engine MANTRA! A name you will hardly forget in the days to come.
This engine is a revolution in the Novarossi off-road engine range, proposing for the first time a square stroke (16.42mm x 16.42mm) on the top range motor, plus a 14mm shaft and new piston/cylinder configuration. Thanks to all of this, we were able to get an elastic and linear power feel, and more torque in medium/high rpm, but incredibly with really low fuel consumption.
NOVAROSSI MANTRA, IS THE NEXT LEVEL!
Tech Specs:
Displacement: 3,49 cc
R.P.M. (max power): 36.500 RPM
Bore x stroke: 16,42x16,42 mm
Sleeve: 4 ports
Rear ball bearings: steel
Front ball bearings: steel
Crankshaft: 14 mm - turbo
Carburetor: plastic - 9 mm - slide
Glowplug: Turbo (C6TGC)
Exhaust position: rear
Starting: standard
Weight: 373 g
Fuel type: 25% nitro
http://www.novarossi.it/2012/index.p...a-offroad.html
Pedro Jesus is offline
Old 06-29-2017 | 01:55 PM
  #9543
Apco1's Avatar
Originally Posted by rcmoe
All I know is my $130 elite 5 is a beast
Thats no lie! Best bang for your buck engine there is. Runs so good you hate to even call it a value engine.
Apco1 is offline
Old 06-29-2017 | 07:56 PM
  #9544
Big B's Avatar
Thanks I picked up a Craftsman 7mm combination wrench and got the fuel inlet nipple turned and ready to go. I am breaking in the Roma tomorrow, I need to pull the cone washer and install the one that came with my TLR flywheel, or I might go with the Novarossi Buggy Clutch. I bought the Novarossi Clutch last week, I really don't know much about it other than its a 34mm. I am going to try the Novarossi Clutch first, if I can't get it to work I will put the TLR Steel flywheel in until the aluminum one gets here. I bought a Losi 8ight-T RTR, but the RTR motor was locked up, so I got the Roma, and I have almost replaced all the parts with the kit TLR parts, just waiting on the Chassis and a few small things, other than that its had everything replaced with kit parts.
Big B is offline
Old 06-29-2017 | 10:45 PM
  #9545
BigInJapan's Avatar
[QUOTE=Pedro Jesus;14964305]The NEW Novarossi
Tech Specs:
Sleeve: 4 ports
BigInJapan is offline
Old 06-30-2017 | 03:30 AM
  #9546
offroad dude's Avatar
I wonder is this Novarossi answer to the OS Speeds
offroad dude is offline
Old 06-30-2017 | 03:50 AM
  #9547
mourinho's Avatar
what exactly do NovaRossi need to answer? they already have excellent engines that compete with everything out there.
this is just another option aimed primarily at buggies.
mourinho is offline
Old 06-30-2017 | 04:17 AM
  #9548
[QUOTE=BigInJapan;14964778]
Originally Posted by Pedro Jesus
The NEW Novarossi
Tech Specs:
Sleeve: 4 ports
Old 06-30-2017 | 11:20 PM
  #9549
HaulinBass's Avatar
Can anyone get me a line on two mantras?
HaulinBass is offline
Old 07-03-2017 | 11:13 PM
  #9550
DGP
Would have been nice if they silicon filled the crank but easily done I guess. Bang for buck Nova's are hard to beat. Apart from 2 x speeds the rest are Nova's. The so called budget P5 with a minimum of work will easily keep up with the Speeds. Gotta love that!
DGP is offline
Old 07-04-2017 | 12:47 AM
  #9551
Roelof's Avatar
4 port and square stroke..... sounds like the same as the Ielasi Tuned offroad engines.
Roelof is online now
Old 07-04-2017 | 05:14 AM
  #9552
savagesam's Avatar
Well Kyle McBride has been running the new engine which is the Mantra, even if his says prototype on the head and he is very happy with the new engine, plenty of power, sharper off the line and a bigger top end over the mito 4, he won the QLD state title last weekend with the engine, more testing to go but looks and sounds good
mourinho likes this.
savagesam is offline
Old 07-05-2017 | 06:18 PM
  #9553
cczjordan's Avatar
Nothing wrong with the long stroke 4 ports, just lagged top end, will 9901-41021 works this time?
cczjordan is offline
Old 07-14-2017 | 09:06 PM
  #9554
Has anyone got the Mantra Engine yet?
wichitafc98 is offline
Old 07-14-2017 | 10:53 PM
  #9555
mustangkillaz's Avatar
Could be. Nova motors are cheap today, and you don't get raped if you know where to buy them. The OS are nice, but expensive af.
offroad dude likes this.
mustangkillaz is offline
