Like Tree352Likes
NOVAROSSI Engine thread....
Old 09-04-2017 | 07:32 PM
  #9691
I have found that usually when my idle is hanging it is because my lsn is too rich and my idle gap is to large. This causes the idle to hang until the rich lsn loads the engine up. I would try reducing your idle gap until the idle falls nicely and then lean the lsn. However, as mentioned above your lsn could be lean too... a properly set lsn should load up some if you let it idle for 20 seconds or so, so the engine will bog a little before it clears out with plenty of smoke. Hope this helps you.
AlbertN likes this.
IOP_Racer is offline
Old 09-05-2017 | 02:35 AM
  #9692
Tzicul's Avatar
This is how I'm doing it:
Performance Tuning Guide
There are many ways to tune a nitro engine but I figure this is the simplest way to do it. This technique is for a fully broken in engine that is ready for a full performance tune. This tuning procedure will set your needles to where they need to be for optimum performance, the engine will tell you all you need to know.
For this method to work the engine has to be at running temperature (or as close to it as possible) as well as having the standard 1mm gap for the carburetor opening.
High Speed Needle
Pull a full throttle pass a couple of times and listen to what the engine does when you let off the throttle. If the it drops right to idle, the HSN is either good or on the rich side. At this point you can lean the HSN in 1/12 turn increments until the idle seems to hang a little after a full throttle pass. If it starts to idle high after a pass it is just on the lean side of a perfect tune. Back the HSN out 1/12 turn at a time after a wot pass until the engine drops right to idle after a pass. Now your HSN is set.
An explanation to what is happening is simple - if your HSN is too lean, after a full throttle pass when you let off the throttle the engine is still lean causing the idle to hang and idle high until the LSN has a chance to take over and meter the right amount of fuel to bring the idle down to normal running speed (given the LSN is set correctly).
If the opposite happens, after a full throttle pass when you let off the throttle it drops to a good idle right away and then starts to idle back up too high, this is a sign that the LSN is too lean. If it comes off full throttle with a good tune and will drop RPM nicely then the HSN is metering the fuel properly but once it hits idle the LSN being too lean will quickly take over causing the RPM to go back up.
Low Speed Needle
Most of this setting was explained above but there are a few little tricks you can use to make sure the LSN is adjusted perfectly. We all know that you don't tune for temperatures, but a temperature gun is very handy for this part. After some full throttle passes with the engine good and warm, bring it in and let it sit for about 10 seconds. At this point take your temperature gauge and hold it as steady as possible on the head, what you want to see is the temp dropping a degree every 4-5 seconds. You want the temp to drop very slightly at idle because when your off throttle the engine should be cooling, if not, the temps will keep pushing higher during on and off throttle running and will cause temperature issues.
This is how I do it and I have tuned a lot of engines for people, whether bashing or racing. I have seen across the board from beginners to veterans that when they hear the high idle after a pull, the first thing they go for is the LSN when in fact it is the HSN causing the issue. If you have any questions feel to contact me at [email protected]
stanleyw808, tmgkbass and AlbertN like this.
Tzicul is offline
Old 09-11-2017 | 11:20 AM
  #9693
Looking for the right hot plug for nov-28-8. I'm seeing a couple of choices just wanting to get the right One.
lighttravler is offline
Old 09-11-2017 | 12:18 PM
  #9694
Big B's Avatar
I use a C6TGC in all of my Novas
Big B is offline
Old 09-11-2017 | 01:12 PM
  #9695
+1 on C6TGC
BoardSlapper is offline
Old 09-11-2017 | 02:31 PM
  #9696
+2.. C6TGC works perfectly in my 28-8RT.
RCTecher12 is offline
Old 09-11-2017 | 07:36 PM
  #9697
Just bolted my Mantra in my buggy....got a bottle through it today on the bench....can't wait to see what she does!!! Brappp!
Pedro Jesus likes this.
motoclay is offline
Old 09-12-2017 | 07:37 AM
  #9698
Hey how's it going. I asked this question in rb I'm pretty sure the rod in engine is a nova rod. Has the 3 stripe mark on it.
Hey how's it going guys, I have a rb bxr sls3 engine. I just cracked the top cooling head fan off and I took apart the engine to check the internals also. It looks like I need a new rod also. It has a lot of play in it and I don't wanna blow it up haha. Anyway does anyone know where I can get rb engine parts for this engine. Searched a little but I'm still at track now. I'm trying to see if it's worth replacing the parts or just start using another engine. Any help would be greatly appreciated! Thanks
jersey is offline
Old 09-12-2017 | 12:04 PM
  #9699
Maybe send am Email to Novarossi World.
I think being the best option.
Pedro Jesus is offline
Old 09-12-2017 | 01:45 PM
  #9700
Thanks, I'll give it a try.
I think the rod is actually a rb 10 rod. Has a 10 on it. Anyone here know if any nova rods work fine? Going to email nova, but if anyone knows much help is appreciated!
jersey is offline
Old 09-17-2017 | 06:07 PM
  #9701
Default Virtus .21
Hello. I have a new virtus .21virtus that I am planning to breakin but I was wondering if you can recommend me a tune pipe that provides good low botton but also good run timw.
moisesing is offline
Old 09-17-2017 | 06:38 PM
  #9702
mourinho's Avatar
9901 with 41001 header, the header is just as, if not more important than than the pipe.
if your not racing at sanctioned events then get the 9853 and hang on
mourinho is offline
Old 09-30-2017 | 03:44 AM
  #9703
Anyone ever had the low speed needle move/turn or change setting while driving their car?Can this happen due to vibration?
joeh5088 is offline
Old 09-30-2017 | 03:55 AM
  #9704
Can any one telle why they got rid off the bloody 3port engine
MadMick is offline
Old 09-30-2017 | 05:21 AM
  #9705
Bloody is 4 Port Enigne.
Loco is 3 Port Engine.
No it continues the sale at the Novarossi Store
The price difference is 10€.
