NOVAROSSI Engine thread....
From: a very small town in wisconsin that is in the middle of absolutely no where
As the pinch goes (wears) away, so does a bit of its power potential. Remember, an engine at operating temp does not have any pinch due to the brass liner expanding at the top. Just think - no pinch when cold means (hypothetically) a perfect seal when cold and a less than perfect seal when hot due to the brass liner expanding more than the piston.
When heating the engine to start it for the first time, don't just place the heat gun at the top of the engine, you need to move it around the sides and even the bottom of the chases where the crank case and bearings are. You need to get a good amount of heat in the engine before trying to prime the engine with fuel this will make it start a lot easier. Make sure your glow ignitor is charged fully, most of the Nova plugs come with a little oil in them, I always take them out first and test them to get that bright glow before trying to start the engine. Replace glow plug, heat all around the engine, top, bottom and sides.....prime the engine, then it will start right up. If it does not fire off and stay running lean the idle screw a hair just enough that it fires and stay running. From there follow who ever you follow for break in. My method I have been running these engines for 20 plus years never has failed me and they last, but we all have our own way. Getting it started for the first time is pretty standard. CHARGE YOUR BATTERIES IN THE GLOW IGNITOR AND BOX FIRST!, HEAT ALL OF THE ENGINE, PRIME IT, THEN IT WILL START,
Mephesto is a very good engine, very easy to drive and gets decent mileage, don't be afraid to run it with a 7.5mm venture to get the power out of the engine. You will still get good mileage with this setting.
YES..... add the water into the pipe and use the black caps that come with the engines to cap off the ends.....cant believe someone asked that...smh. Leave pipe in freeze over night at the most and it will push some bad dents out of the pipe. Do not leave the pipe in the freezer to long as it will hurt the inside of the pipe baffles.
To clean the pipe, soak in concentrated anti freeze in old crock pot on low for about 5-6 hours. Take out and polish with clean towels and chrome polish. A Dremel and polish tips work good or a big table buffer works even better.
I have the Novarossi Mephisto engine and usually run the 9901 pipe. Does any pipe labeled as 2135 work? I know Hipex makes the 2135 for Novarossi and see that Hipex makes their own branded model in black... wondering if 2135 is universal to all 2135?
2135 is an EFRA registration number and with that registration all dimensions are noted and may not be changed. What may be different is the header connection, thickness and coating.
I'm sure this has been asked before, but new to Novarossi. Have a Bonito in a truggy (NT48.3), and was wondering what is a good pipe/header combo. Medium size track, with one straight and fairly tight infield.
I'm currently running the 41031 conical header with the 9901 pipe on 7 port Rolling
haven't got it fine tuned yet after changing front bearing still pretty rich and was pitting at like 7mins on truggy
most bottom setup ..
352Likes
