NOVAROSSI Engine thread....
got the mephisto gt5 fully broken in, shes ALOT of motor.IMO nova should throw a rubber bearing in it and sell it as the high end "truck" motor choice alongside the 4 port mephisto(buggy). even with a hipex 2108/50mm header it was pulling some serious rpms while still feeling snappy
You can say it is a great buggy engine but you are talking about a Murnan modified which may not be compared with the normal engine although even then I would expect it is a good engine.
ran another 1/2 gallon through the mephisto gt5 in my truggy around the track today. loving it so far didnt get any timed tests as i was learning the track but im rather happy for something I bought for no reason other than i was interested in how it would do.
liked the 2095 low noise on my "full monty" mantra in buggy, but broke my fuel tank driving stupid
If you watch closely the os plugs are a little bit different in shape. In my opinion use what was designed to.
IIRC the issue was going back and forth. I.e. if you start with OS maybe it's OK, but then you have to stay with OS plugs. You can't go back and forth or you'll screw up the button... I'd go with a Nova #6 as advised above..
I want to update about pipes..
I was running my virtus.21 with the 9901ss/41032, good power, good mileage, good bottom and top and temps at 284F.
The past weekend I runned the 9886ss which I cerakoted with the 41031 manifold. I tunned with the 9901ss/41032 runned it and swapped it on site with the 9886ss/41031.. The difference was massive.. I also richened tha hsn about 4 hours and had more power with temps at 260F.
I runned those compos and both of the seem close in performance but never back to back with each other.
Performance wise 9886ss/41031 is a bomb, temps are better but mileage is worse than 9901ss/41032 but I don't really care about mileage so I am keeping the 9886ss/41031 for now on on every nova I run..
Recently bought a mito 4 and a rolling . Love the mito 4 but not fast enough. The rolling has the speed but the fuel milage is aweful. Cant even get 6 minutes. Using a 9901 pipe on both. Any suggestions? Is there another motor that has the speed if the rolling but better fuel economy ? Mephisto?
I have 2 rollings. 1 for truggy and one for buggy. 7mm Venturi in truggy and 6.5mm Venturi in buggy with 021 header and 9853 pipe on both. I can go 10min pit stops in a race almost every time. I noticed on the rolling that I was able the lean out the LSN more then some of the other engines I have tuned.
houston full monty mantra
352Likes
