NOVAROSSI Engine thread....
With the virtual impossibility to get a hold of NR parts right now (if ever again) does anyone have any tips for different branded parts that are compatible or a source of OEM parts?
in particular, orings, piston clips, etc. and potentially, cranks, liners and pistons.
this is for Plus21/4 type motors in particular.
If the closed doors is official we would have read it on any RC related news site but we do not.....
But replacement parts? Beraings can be found at Boca, TKO and even Ebay. MAX is using Novarossi parts up to his 2019 model and did take over some Novarossi machins to produce the engines by him self but the 2020 model has a different rod with different dimensions. Glowplugs from other brands will work as also cooling heads of other engines will work.
If you need a P/S set then throw some bucks extra with it and you have a new engine.
The is a rumor that Novarossi is bought bij an USA based company....
Novarossi direct is here in the US. Why wouldn't they be shipping? I'm sure they are only working with existing inventory. For example: haven't been any CT06 plugs available in months.
I've just bought a novarossi engine rolling from the guy in Europe who I believe bought a lot of them and selling them on eBay.
My only concern is glow plug someone said the p3 is a direct replacement or can be used please quote me if am wrong,
The P3 is a hotter plug then the recommended CT06 nova plug and I have heard the P4 is actually better to use in Nova engines because its a little cooler then the P3.
I've also heard that if you use the P3 it is recommended to add a .1mm head shim for timing/firing purpose.
Do we know for a fact that heat ranges are the same across all brands of plugs/engines? In other words, is it possible that a P3 and a CT06 are actually the same heat range plug because there's no standard?
I can’t give specific numbers but a os p5 is a little cooler than the ct06 and the p4 is a little hotter than the ct06. I run a P4 in my Mephisto right now and it idled a little better than the ct06. When the plug in my Rolling dies I will try a P3 in it has the head clearance is more than the Mephisto.
352Likes
