Like Tree352Likes
NOVAROSSI Engine thread....
Old 06-24-2012 | 02:38 PM
  #3241
Suspended
Originally Posted by merdith6
That's just silly. I had a toro team that did that all the time, it is similar to the bonito. I will never buy another extra long stroke 7 port.
I know a few guys that run the Bonito and Toro team and they never have had problems with em.
I don't see Novarossi putting out a bad engine..... Unless somehow, he got a defective one, which must be rare, because its the first time I've heard of one.
rcuser567345 is offline
Old 06-24-2012 | 03:58 PM
  #3242
merdith6's Avatar
Default True
I just had trouble with them personally. I'm not saying they are all bad, or anything other than I had trouble and I'm a pretty darn good tuner and experienced racer. I'll stick with my reliable p5 and plus-4.
merdith6 is offline
Old 06-24-2012 | 04:08 PM
  #3243
megasaxon's Avatar
never had a problem with my toro, idles all day long and is the most consistent running engine i've ever owned. My p5 is pretty reliable, but i rarely even touch a needle on my toro
megasaxon is offline
Old 06-24-2012 | 10:47 PM
  #3244
Nitro$junkie's Avatar
i love my Toro Nero the things a raging bull just put a new front bearing in it and had to take it out of my buggy and dropped it back in my truggy the things a animal!
Nitro$junkie is offline
Old 06-25-2012 | 07:45 AM
  #3245
Guillermito's Avatar
My 4BTT yesterday he broke the piston, and had less than 2 gallons and less than a year ...
I think I'll buy a OS 21 Speed.
Best Regards.
Guillermito is offline
Old 06-25-2012 | 07:47 AM
  #3246
Good Luck with you future purchase. I'd still like to know what caused a strange breakage.
Chris Reilly is offline
Old 06-25-2012 | 07:53 AM
  #3247
beidle99's Avatar
Best of luck with the os. You do know that novarossi makes the best micromotors in the world right? To brake a piston leads me to believe mechanical falure do to outside stress (piston locking tool or not having the piston at tdc when removing or installing rear plate)
To each his own
beidle99 is offline
Old 06-25-2012 | 07:55 AM
  #3248
aznitronut's Avatar
QUOTE=beidle99;10901063]Best of luck with the os. You do know that novarossi makes the best micromotors in the world right? To brake a piston leads me to believe mechanical falure do to outside stress (piston locking tool or not having the piston at tdc when removing or installing rear plate)
To each his own[/QUOTE]
aznitronut is offline
Old 06-25-2012 | 08:01 AM
  #3249
The piston was broken when the engine was at low rpm. It is well that Novarossi is very good brand (I'm in the hobby 30 years ago), but I can not use an engine that lasts less than two gallons ...
Old 06-25-2012 | 08:11 AM
  #3250
megasaxon's Avatar
never heard of a 2 gallon old Novarossi breaking anything, unless the user did something to it. Doesnt the btt have the good team piston in it too? Only pistons i've broken were the cast pistons and the engines had a dozen or more gallons on them
Old 06-25-2012 | 08:13 AM
  #3251
My OS was bad long before 2 gallons. I've been doing this just as long as you. Never had any problems with all the Nova Rossi I have owned. I tried one OS and my experience was not good. It doesn't mean I wouldn't own another.
What do you want for what is left?
Old 06-25-2012 | 08:14 AM
  #3252
We will see that engine buy now. I also like the Bonito XLB or XLBS, to use Venturi 5.4mm
Old 06-25-2012 | 08:15 AM
  #3253
I was also the first time I hear it, and just happened to my engine!
Old 06-25-2012 | 10:07 AM
  #3254
beidle99's Avatar
My Btt is just past 2 gallons and is still tight when cold and when up to temp is still hard to turn over when wearing gloves. Sorry to hear about the bad luck on your Nova, but what part of the piston broke?
beidle99 is offline
Old 06-25-2012 | 11:15 AM
  #3255
Thank you! Is broke at the bottom (I put a photo), and the truth has much oxide with so few liters. Or is it normal that oxide?? Fuel use is the Byron 25/11, always consumption you fuel after using the engine, and put After-Run.
