Like Tree352Likes
NOVAROSSI Engine thread....
Old 06-26-2012 | 11:39 AM
  #3271
nitroexpress's Avatar
Adam Drake says.
" I run the same venturi with the new carb (24065). The main benefit is an increase in runtime."
nitroexpress is offline
Old 06-26-2012 | 12:50 PM
  #3272
houston's Avatar
Originally Posted by nitroexpress
Adam Drake says.
ugggh
houston is offline
Old 06-28-2012 | 05:20 AM
  #3273
theerm's Avatar
I am finishing putting my serpent gt together. I was going to use the short nova header and a 9886.
With the roma 25. Well I put it together and had a change of mind and now I have put on the long header and a 2052. It fits a bit better, the exhaust mounting wire was to short for the 9886
Will this be a good combo or should I make the 9886 fit.
I hope someone with more experience than me can advise.
Or maybe something different all together.
Thanks in advance.
theerm is offline
Old 06-28-2012 | 06:02 AM
  #3274
rceefreak's Avatar
gmk suppy makes an exhaust hanger u can bend and cut to ur desired length. As for pipe I'm not familiar with the 2052. One of the engine guys will chime in on that one
rceefreak is offline
Old 06-28-2012 | 06:13 AM
  #3275
theerm's Avatar
Thanks, I will order one from gmk, they look good.
Cheers.
theerm is offline
Old 06-28-2012 | 09:22 AM
  #3276
freefallmarine's Avatar
Originally Posted by houston
Yes i did try the 24065 and i am not going to share my thoughts , sorry guys
That's all you had to say Monty! Beside's, what's wrong with the current carb? All mine work great!
freefallmarine is offline
Old 06-28-2012 | 12:32 PM
  #3277
Grinder's Avatar
Thanks in advance.
The 2052 should work great with the Roma.
Grinder is offline
Old 06-28-2012 | 06:16 PM
  #3278
houston's Avatar
24063 & 24069 r great carbs
houston is offline
Old 06-29-2012 | 05:20 AM
  #3279
aussies1129's Avatar
Thanks in advance.
I used the gmk exhaust spring to fit the 9886/21 combo its awesome
aussies1129 is offline
Old 06-29-2012 | 07:08 AM
  #3280
scrapsz's Avatar
Curious...is the main diff btwn 063 & 069 carbs the inside diameter of the neck?
scrapsz is offline
Old 06-29-2012 | 11:41 AM
  #3281
Guillermito's Avatar
That measure the venturi does better to Bonito 7XLB? Is for a Truggy Mugen.
Thanks. Best Regards.
Guillermito is offline
Old 06-29-2012 | 11:52 AM
  #3282
What is this I'm hearing about an air intake hole in the Bonito that can cause a possible air leak? And some kind of silicone used to fix this issue? I havent incountered this problem with mines but I only barely have a gal on it.
rcmoe is offline
Old 06-29-2012 | 01:23 PM
  #3283
kja812's Avatar
Neal's (CRE) video.... http://youtu.be/gdt2luUlbuI
kja812 is offline
Old 06-29-2012 | 01:42 PM
  #3284
hookem34's Avatar
R/C Tech Elite Member
It's the Vacum Return port and is in EVERY Nova and Nova-based engine. Not a problem with stock engines, but modified engines, especially high HP ones, are seeing some issues. The video below explains everything.
I run all of Neal's Nova engine lines and have no issues with mine because I run Werks fuel, which is thicker than most.
hookem34 is offline
Old 06-29-2012 | 02:18 PM
  #3285
Ive heard of this vid and I just watched it. I'd hate to imagine that this could possibly be happening to my gal old $400 Bonito . Has any of you guys incountered this problem? My engine man seems to be sceptical that this is a air leak problem but he has done this repair for a buddy of mines recently and is waitng to see if it fixed his problem. Have any of you guys experienced this problem and is it reccomended to get this done to be on the safe side? Also has Novarossi said anything about this?
rcmoe is offline
