Like Tree352Likes
NOVAROSSI Engine thread....
Old 07-01-2012 | 01:03 AM
  #3301
houston's Avatar
Originally Posted by Jaz240
Has anyone ever tried the P5 P/S/R in the +4 with the +4 crank and case? I have good usable parts from both engines that can be combined if it works.
Parts will not fit
P5xlt od on sleeve 19.5mm plus 4 od 19.2mm
houston is offline
Old 07-01-2012 | 05:59 AM
  #3302
shimano's Avatar
Default Roma25
Hey guys, I know this has been asked, but what front bearing comes with the Roma. I bet it's not the 17011.
shimano is offline
Old 07-01-2012 | 07:41 AM
  #3303
Jaz240's Avatar
Originally Posted by houston
Parts will not fit
Thanks for the replies....bummer
Jaz240 is offline
Old 07-01-2012 | 07:47 AM
  #3304
aussies1129's Avatar
17007
I just put some tko ceramics in mine
7x19x6 front
14x25.8x6 rear
at about the 5 ltr mark still on the rich side temping about 220 so far so good
my local supplier here has got another set if you want?
cheers
aussies1129 is offline
Old 07-01-2012 | 01:36 PM
  #3305
chevelledude's Avatar
What would the pipe of choice be for me for my truggy with a P5xl?
chevelledude is offline
Old 07-01-2012 | 02:03 PM
  #3306
From: Lake View Terrace, CA. ~ Where Rodney King got his Asswoopin!
Thumbs up RTT
You Might try reading the thread (RTT) or the P5XLT thread. It's in there.
chiefin on 420 is offline
Old 07-01-2012 | 04:32 PM
  #3307
novarossi 9886/21 or 9901/21 or 2096/21 for top end
Old 07-01-2012 | 06:02 PM
  #3308
megasaxon's Avatar
for truggy, 2084/21 or 2096/21 on the p5xlt, plenty of bottom end with those combos
megasaxon is offline
Old 07-01-2012 | 07:37 PM
  #3309
Thanks for those suggestions guys. Always good to hear what others like.
Old 07-01-2012 | 09:58 PM
  #3310
Som3R3tard's Avatar
Hey guys got a 21+7fms with a dynamite 053mr. Ambient air temp was 105. Motor came off track at 295. Seems like it didn't have that much top end speed. I couldn't keep up with the ninja or bullet motors on the straights. What should I do? Motor might have 2gallons on it. Seems to still have compression even when hot. Thanks in advance
Som3R3tard is offline
Old 07-01-2012 | 11:12 PM
  #3311
merdith6's Avatar
Default Hmm
Well the fms has top end, so my first thought is you may be lean. Leaning out a motor can make it faster up to a point, then it's starving for fuel. When you pull the trigger it's giving more fuel and more air not less. Open up the top end to flush, retune the bottom and idle, then if that doesn't do it, check your gearing. what buggy, or truggy. The FMS doesn't run that hot, although some will tell you it's a good temp, it's not typical. Mostly 250-270 on a hot day. Check the clutch too it may be slipping a little too much, and it sounds silly but make sure the throttle is physically opening up just shy of fully open. Leave a little wiggle room there for jumps and so on.
merdith6 is offline
Old 07-02-2012 | 03:44 AM
  #3312
shimano's Avatar
Originally Posted by aussies1129
17007
7x19x6 front
14x25.8x6 rear
cheers
Are the ceramics a hassle to keep clean, what type of maintainace do you expect to have to do. Our track is quite dusty.
shimano is offline
Old 07-02-2012 | 07:06 AM
  #3313
aznitronut's Avatar
Try a different pipe would help also, 053, is a bottom end pipe, try 9901or 2096, either will make a big difference.
aznitronut is offline
Old 07-02-2012 | 01:07 PM
  #3314
omarwashington's Avatar
17007
7x19x6 front
14x25.8x6 rear
cheers
was going to ask a similar question but I take it that the 7x19x6 TKO and Boca front bearing will work despite the nova size says 7x19x6.3?
omarwashington is offline
Old 07-02-2012 | 01:40 PM
  #3315
houston's Avatar
99.9% of all front bearings are 7x19x6mm on the o.d. , nova 17011 are 7x19x6x6.3mm and the 6.3mm is that the inner race is stepped out to provide extra room for the two seals that are on the outboard side of the bearing and so there is no need for washers behind the collet on most all factory clutch systems
houston is offline
