NOVAROSSI Engine thread....
#4021
Suspended
really?
that is not true man , novarossi is all about bringing the best they possibly can , the only real challenge they have right now is competing price wise with all the low cost and some lower quality engines .
that 17011 is the baddest front bearing on the planet , if you think you need to plug "the vacuum port" do it but i guarantee it is not necessary , its a total non issue . btw , many other manufacturers have the exact same "vacuum port" , why is it only exclusively being talked about for novarossi engines?
flavor of the week to some
But I don't think they will remove it anyway.
#4023
lil-no dust - lightly oiled inner outer
heavy dust - medium oiled inner light outer and vet wrap
many levels in between
this is the novarossi thread though , lets all talk novarossi !!!
awesomest engines on the planet
#4024
thanks Rex...that is exactly what I thought....... Same taper angle, same thread pitch... same bottom diameter.... plug seats perfectly with no issues....
.....Issues only from over tightening ......... For those who don't know Rex is a tool and Die maker with access to the most precise measuring tools and techniques.........An Optical comparator is not a joke.......
.....Issues only from over tightening ......... For those who don't know Rex is a tool and Die maker with access to the most precise measuring tools and techniques.........An Optical comparator is not a joke.......So now we use an OS plug in a Nova without "over tightening." What torque value is that?
Not exactly using a torques wrench when replacing my plugs. And when I'm racing and all I have is a glow plug wrench and a quick glow plug change is required, I'm not exactly hoping my mechanic is thinking about how much to torque the plug.
Rather not take the chance.
#4025
I always thought that hole was for lubrictaion of the front bearing. If a crankcase and cranck is perfectly matched, you could will never have a problem with a front bearing leaking or sucking air to mess up your tune. In a perfect engine, the front bearing would only get luberication from that whole.
Well, maybe i was wrong.
#4027
So what we do know is that there are differences in plugs, and over tightening can ruin a Nova button head.
Besides I prefer my glowplugs tight and fresh
#4029
Suspended
Snug it and tighten it to where you feel is enough that it won't come out but not gorilla'd
#4030
#4031
#4032
I contact Nova they sent me to their engine designer / engineer. I explained the debate and details and asked if he could determine if a OS plug is usable in a Nova Turbo button.. I'm waiting for a response once received I will post. I personally won't run OS plugs in my Novas cause of my experiences.
#4033
If i dont remember wrong i did use a 4mm first.I could lurk it around in the screwhead and it did ruin the screws a little.
Then i find a bigger and thicker 5mm that fits just exactly in the screwhead.
I had to hammer it a little to fit.And with the bigger handle of this screwdriver it was a piece of cake to get it loose.
#4034
Suspended
http://clockworkracingengines.com/co...-pcs-am-130992
Bigger handle=more torque, so it will remove em. I have those drivers, they're awesome.
#4035
really?
plug explanation
plug explanation
Maybe it is the tuning,maybe it is the vacum i dont know.
When that is said i did already have 3 novas.
The first one 21-4 was never pluged and lasted around 40 liter,didnt change or do anything to it.
Second one 21-4 did only last around 30-35liter then the clips holding the piston pin did came of making scratches.
The first one i then did change the bearings,and only the bearings just to try.
It was almoust impossible to tune right,but i did get pretty close.
Then i did see the video about this hole needded to be plugged.
So i did.Then it was more easy to tune and it did idle better.The bearings was not enough to make it good after 40 liter,i did expect this,but anyway...
I also have a 21-4btt and i did have a runaway with it ruining the bearings.
This one had around 12 liter.When i changed to avid back and front bearings i also pluged the vacum port.
And it idles better and is more easy to tune.I hardly need to adjust the needles anymore.
So as i can see it it is not so importent to do it and maybe i loose a few second on a tank or something i dont know.But it also dosent hurt to plug the vacum hole
352Likes
