Like Tree352Likes
NOVAROSSI Engine thread....
Old 06-22-2012 | 03:25 PM
  #3226
bigjayjay1's Avatar
Originally Posted by Dr. Evil
According to Internetslang.com, FTW means
F*** the world???
so are you trying to say use the Hudy tool and to heck with every else???
LOL>.
Funny im always looking up these text slang words and im 40 guess im getting old
bigjayjay1 is offline
Old 06-22-2012 | 04:03 PM
  #3227
For The Win I hope it means.
Never heard of internet slang website.
Chris Reilly is offline
Old 06-23-2012 | 03:24 PM
  #3228
Suspended
FTW means For The Win lol.
rcuser567345 is offline
Old 06-23-2012 | 06:32 PM
  #3229
Dr. Evil's Avatar
Talking FTW
Woops???
I like the other one better.
and yes... I looked that one up...
Maybe my brain is getting tooo full and i can't retain all these acronyms.
Geesss..
Swell....
LOL>.
Dr. Evil is offline
Old 06-24-2012 | 07:29 AM
  #3230
Diff Balls's Avatar
This is my BTT, just broke it down for the first time. Is the rust normal?
It has about 2 gallons on it (Odonnel speed blend and Byrons 9%). If the motor sat for more than a couple of weeks, I would run the fuel out and use ARO.
What is the best way to clean it?
Diff Balls is offline
Old 06-24-2012 | 08:38 AM
  #3231
Muggydude's Avatar
Using ARO with a lint free cloth actually helps remove a lot of rust
I use it on other stuff too because it works so good.
Muggydude is offline
Old 06-24-2012 | 08:51 AM
  #3232
beidle99's Avatar
In the future don't run the fuel out if your using byrons. Just stop the motor before it runs out of fuel, dump whats left in the tank and store it with the crank/clutch pointed down it will keep all the oils inside the motor and coat your bearings.
beidle99 is offline
Old 06-24-2012 | 09:12 AM
  #3233
Default Bonito realibility problems
removed
RookieForever is offline
Old 06-24-2012 | 09:19 AM
  #3234
houston's Avatar
Originally Posted by RookieForever
Ok, I have been now fighting with this Novarossi Bonito .21 engine. And I have had lot of problems with those suddens engine stop. I have not found any common reason forthosr shut downs. Only thing is the motor makere. I run with that small venturi, use 25% fuel, good pipe. Setting are now almoust factory 4 LSN and little rich side in HSN. Any seggestion what to try before I will change the engine brand?
That could be soooo many things man
Kinda hard to understand your english but it sounds as if we need more detail about your setup , ie. Pipe, plug, clutch, chassis , fuel brand, etc.
Could be as simple as a clutch or engine is not broken in all the way ?
houston is offline
Old 06-24-2012 | 11:20 AM
  #3235
merdith6's Avatar
Default Crank
I use a wire wheel on my dremel. It works perfect. and some wd40.
merdith6 is offline
Old 06-24-2012 | 01:40 PM
  #3236
portyansky's Avatar
Trying to help a buddy out... What glow plugs aside from Nova can you use with the p5xlt? I know ODonnell was an option, but they are no longer made. Can he use OS or Dynamites?
portyansky is offline
Old 06-24-2012 | 01:45 PM
  #3237
If you use O.S plugs you'll have to stick with them..
Dynamites should be OK.. Werks #5 is good option..
FLDan is offline
Old 06-24-2012 | 02:04 PM
  #3238
Suspended
Something tells me you didn't break in the engine...
Don't start blaming Novarossi, the engines are made perfect, only thing that can cause problems is the user....
Old 06-24-2012 | 02:06 PM
  #3239
Suspended
Odonnell does still make plugs? amain sells em.
Other than that, Werks #6 or #5 or GRP #6
But Novarossi plugs will be the best... C6TGC
Don't use the O.S. plugs...
Old 06-24-2012 | 02:20 PM
  #3240
merdith6's Avatar
Default Ha
That's just silly. I had a toro team that did that all the time, it is similar to the bonito. I will never buy another extra long stroke 7 port.
merdith6 is offline
