Like Tree352Likes
NOVAROSSI Engine thread....
Old 07-10-2012 | 06:09 PM
  #3376
B00t13g's Avatar
Finished the break in on my plus 21-4 team c today. I can't wait to get it on the track!
B00t13g is offline
Old 07-11-2012 | 03:37 AM
  #3377
shimano's Avatar
Default Bearings
Hey guys, what other front bearings do nova make with a 6.3 inner race?
shimano is offline
Old 07-11-2012 | 08:17 AM
  #3378
beidle99's Avatar
Do you mean the 17011 (steel) or 17012 (ceramic) The are both the best in the business and have put the 17011 in other manuafactures blocks when a suspected bearing problem came up. I pulled the bearing that came in my plus 4 at 2 gallons and installed a 17011.
beidle99 is offline
Old 07-11-2012 | 12:36 PM
  #3379
guss2009's Avatar
Am i the only one having problem mounting my nova engine on the losi 8ight quick engine mount? All my other engines mount right with no problem. When i try to put the engine on the buggy mount, one side is up and the other side mounts right. Any help will be appreciated.
guss2009 is offline
Old 07-11-2012 | 01:29 PM
  #3380
houston's Avatar
Chamfer (grind a relief angle) on the inboard side of each mount
houston is offline
Old 07-11-2012 | 01:41 PM
  #3381
aznitronut's Avatar
Did you separate the 2 peices that mount to the engine from the 1 piece that mounts to the chassis? When you attach the 2 pieces to the engine, make sure you can see the Arrow pointing forward on both pieces, and do not tighten them down to you attached it the the 1 bottom piece that attaches to the chassis, once you have the.engine sitting in position on top of CHASSIS piece, make sure you have the guide pins lined up to so the mounts are flat on both sides, now you can tighten up the Screws from.engine pieces, to the chassis piece, then set your great mesh, tighten down the bottom screws and your ready for go, after you have all the the other stuff hooked up, fuel and pressure lines and linkage.
aznitronut is offline
Old 07-11-2012 | 01:43 PM
  #3382
aznitronut's Avatar
That too! Thanks Monty.
Old 07-11-2012 | 04:03 PM
  #3383
guss2009's Avatar
Yes i have the engine mount separate from the chassis mount. The arrows are forward on both engine mounts. When i sit the engine with the mount and loose screws they sit perfect. Once i tighten the screws and remove the engine from the chassis mount it doesnt drop back onto the chassis mount like it did when the screws were loose.
When i get home i will check out the engine mounts and do what monty said.
guss2009 is offline
Old 07-12-2012 | 12:15 AM
  #3384
shimano's Avatar
Default ..
Yes, do they make any other bearings other than the 17011 with an inner race of 6.3?
shimano is offline
Old 07-12-2012 | 12:16 AM
  #3385
Hey Guys, i´ve read some post about problems on BONITO engines, concretely, im interested on know if any of you have problems with dust into the engine trought front bearing. I´ve broke various BONITO and i dont find any explanation except the fuel that not have castor oil. I dont cover the vacuum return port....
What tip recomended for fix this problem???
david_atv is offline
Old 07-12-2012 | 12:22 AM
  #3386
shimano's Avatar
I'm asking because I have a Roma 25 that comes with an other bearing and a Nitrotec by novarossi, r21, and it would appear to have the 17011 in it. Engine build no is 884 I think so was built a little while ago. I'm nearly positive that it has 17011. Yet the Roma build no is 400, so is only just built recently and def doesn't have a 17011.
Any thoughts guys?
shimano is offline
  #3387
houston's Avatar
Yes but not any that are worth a crap
houston is offline
Old 07-12-2012 | 12:26 AM
  #3388
houston's Avatar
Any thoughts guys?
Sorry to say but that bearing in the roma is not that great of a front bearing in comparison to the 17011 , i would just keep a very close eye on it
Probably build/batch 884/11 and 400/12 2011 & 2012 , 2012 newer of course ,i explained this a few (3-4 pages) back
houston is offline
Old 07-12-2012 | 01:51 AM
  #3389
houston, can u tell about the problem that i described few minutes ago?, thanks!!!
Old 07-12-2012 | 02:19 AM
  #3390
shimano's Avatar
Can you tell me if the r21 Nitrotec by nova Rossi would have the 17011 front bearing. I have two one the way away, but just curious.
shimano is offline
