Like Tree352Likes
NOVAROSSI Engine thread....
Old 07-06-2012 | 12:20 PM
  #3346
I have the P5 with Dynamite 086 and 053 pipes. Since I am planning to participate in a IFMAR approved event, only listed pipe can be used. I intend to buy a Nova 9901. Can I use the Dynamite header? Which header will work?
rcindia is offline
Old 07-06-2012 | 01:01 PM
  #3347
pravesh736's Avatar
hi ajo .. yes the dynamite header of 086 n 053(almost same as 41021) fits my 9901ss too .. i dont know if its legal or not .. nova 41021 header will work good .. but for the p5 id recommend 9886 in buggy or 2096 .both come in ss
pravesh736 is offline
Old 07-07-2012 | 11:49 AM
  #3348
houston's Avatar
2096ss/41021
houston is offline
Old 07-07-2012 | 01:19 PM
  #3349
merdith6's Avatar
Default Interesting pipe.
It has a stinger reinforcement. It looks like a thin walled pipe but I'm just guessing.
merdith6 is offline
Old 07-07-2012 | 02:13 PM
  #3350
houston's Avatar
i'm good with the super strong pipes , that has been out for about 4 months now actually , thin walled pipes are good but do not offer the protection of the ss pipes
houston is offline
Old 07-08-2012 | 03:34 AM
  #3351
aussies1129's Avatar
bloody hell I have busted 3 screwdrivers already one of being a hudy driver trying to get out the last two head bolts on my roma I have put the heat gun on but have given up trying to get the last two actually ran out of screwdrivers, this is about my 10th nova engine and I have never seen them this tight from the factory I am getting worried as the screw heads are showing signs of damage
aussies1129 is offline
Old 07-08-2012 | 08:17 AM
  #3352
houston's Avatar
You busted the 5.8mm hudy flathead made for novarossi engines? Really?
houston is offline
Old 07-08-2012 | 02:19 PM
  #3353
revo61's Avatar
Was it this one?
revo61 is offline
Old 07-08-2012 | 02:39 PM
  #3354
merdith6's Avatar
Default Yep
I like the SS pipes myself. I just thought it was interesting to see they do make some sort of reinforcement after so long without one. I don't use the 9901 anyway. I have one but it looks really new.
merdith6 is offline
Old 07-08-2012 | 08:11 PM
  #3355
B00t13g's Avatar
I literally just picked up a plus 21-4 team c and have an os 2060 and a 2090 from my os motors, will I really be losing much by using one of those? If not which pipe would you recommend of those two? If yes, which pipe should I get? Werks 2058, nova 2096 etc?
B00t13g is offline
Old 07-08-2012 | 08:13 PM
  #3356
Quad Racer 34's Avatar
Is it going in a buggy or Truggy?
Quad Racer 34 is offline
Old 07-08-2012 | 08:32 PM
  #3357
houston's Avatar
I would recommend 9901ss or 2096ss but i would bet the "new" 2090 from os would work very well since the os-xz line is now the same bore x stroke as novarossi
Let us know
houston is offline
Old 07-08-2012 | 08:54 PM
  #3358
B00t13g's Avatar
Let us know
Of the two pipes you reccomended which would be smoother or just have good power all around? I assume you would reccomend the 41021 manifold? You're the man! It's for buggy!
B00t13g is offline
Old 07-08-2012 | 10:22 PM
  #3359
Originally Posted by revo61
no it was one of the older hudy flat heads but after a bit more heat and a tap on top of the screw head with a punch they finally cam lose but that was close new hudy screwdriver and screws on its way
probably a question for houston, the btt and the roma cooling heads are they the same? cheers
Old 07-08-2012 | 10:27 PM
  #3360
houston's Avatar
i have been very very happy with the 2096ss/41021 in the buggy
houston is offline
