Like Tree352Likes
NOVAROSSI Engine thread....
Old 07-22-2012 | 04:52 PM
  #3496
rider313's Avatar
Originally Posted by aussies1129
question replacing front bearing on my btt do I need to remove one of the covers on my tko front ceremic bearing or just leave it?
cheers
Leave them both on.
rider313 is offline
Old 07-22-2012 | 05:00 PM
  #3497
Suspended
Originally Posted by rider313
Leave them both on.
+1. Leave them
alwayswin is offline
Old 07-22-2012 | 06:30 PM
  #3498
dirtdog's Avatar
Originally Posted by triplebvalp
Thats the one i was refering too. But is that exactly how you should break in a novarosi? Trying to read there break in procedure comparing it to houstons is quite different...
dirtdog is offline
Old 07-22-2012 | 07:20 PM
  #3499
lennybigblock's Avatar
I change my engine in my truggy, Novarossi I want one that is capable + 10 min run time and good power.How to choose?
lennybigblock is offline
Old 07-22-2012 | 07:33 PM
  #3500
jnorwood_losi's Avatar
BTT, Bonito, Plus 4 Team, P5 (maybe, no personal experience) ect... Just have to use a low to mid venturi, and THROTTLE CONTROL
jnorwood_losi is offline
Old 07-22-2012 | 07:36 PM
  #3501
[QUOTE=jnorwood_losi;11005321]BTT, Bonito, Plus 4 Team, P5 (maybe, no personal experience) ect... Just have to use a low to mid venturi, and THROTTLE CONTROL [/
bonito is what it would be a good choice and what goes with this engine pipe
Old 07-22-2012 | 08:09 PM
  #3502
I use 9901 and 41021 and really like it, BUT I have not done allot of pipe experimenting
Old 07-22-2012 | 08:12 PM
  #3503
ok thanks
Old 07-22-2012 | 09:44 PM
  #3504
houston's Avatar
do it however you see fit , you will find out ways not to break in your engine in the interim of finding the "best" method
running my engine at half throttle for 30 min. then race tuning it is not what i consider a "proper" break in method if you want your engine to last , you do pay $$$ for your engines right?
houston is offline
Old 07-22-2012 | 11:25 PM
  #3505
bigjayjay1's Avatar
Was helping a buddy with his P5 this weekend bought a double seal front bearing and a rear ceramic upon inspection his front bearing was solid with dirty actually could see the dirt pouring out when i was cleaning . Motor is under two gallons we plug the breather hole but I was shocked anyone running a P5 highly recommend a change out even if your bearing doesn't have issue. Byron's 11 percent oil is being used. I did mine early so I didn't see issues but I would inspect if your running a P5
bigjayjay1 is offline
Old 07-22-2012 | 11:53 PM
  #3506
dirtdog's Avatar
So u recomend your way to the tee for a novarosi? How about castor oil? I run vp fuel 30 percent nitro. I beleive the oil conent is only 9.5 percent. Should i be concerend about this? Should i add oil to the gas for break in?
dirtdog is offline
Old 07-23-2012 | 12:15 AM
  #3507
I've been doing research on my next engine. In which is my first "truggy engine". I've narrowed it down to the p5 or bonito. What are some of your experiences with both engines in a truggy? I've read both engines are workhorses! Thanks in advance..
nrm1977 is offline
Old 07-23-2012 | 05:00 AM
  #3508
Maximo's Avatar
keep an eye on that engine...even with a 17011 the issue will come right back..the 17011 helps for a bit, but its only just a bandaid .......
Maximo is offline
Old 07-23-2012 | 07:29 AM
  #3509
JEDI BASS's Avatar
THANKS!!
JEDI BASS is offline
Old 07-23-2012 | 09:15 AM
  #3510
triplebvalp's Avatar
Hey Maximo,
??? Care to elaborate on what you mean? I will be receiving my P5 Wednesday afternoon and might be a little concerned that I ordered the wrong engine.
triplebvalp is offline
