Like Tree352Likes
NOVAROSSI Engine thread....
Old 10-08-2012 | 04:19 AM
  #4246
Originally Posted by aussies1129
trying out a hudy break in bench has anyone got any suggestoins when running in nova engines on this thing??
cheers
use a competition heater or aluminum foil around the cooling head to keep the temp up , as the prop will cool the engine quickly. 1/10tire foams work well too
menzo is offline
Old 10-08-2012 | 04:25 AM
  #4247
blade954's Avatar
Trying out a HUDY break in bench has anyone got any suggestions when running in nova engines on this thing??
cheers
You have to turn the carby around so with the blades on check that it wont strike the carby, Make sure all bolts are secure. I use a old towel and keep it under the exhaust to collect all the fuel and oil.I also make a template out of cardboard and place it in between the carby and head the amount of air that the blades turn out cools the engine to much...all my engines get the first 800ml to a liter on the bench where i can keep watch and heat into the engine... Then in the car..
blade954 is offline
Old 10-08-2012 | 08:01 AM
  #4248
PERROTTO's Avatar
so my btt started to idle like crap and was stalling and after blowing two nova 6 plugs, so at the end of the day I took apart and noticed 3 or 4 heavy scratches running down the piston.
could this be the result of the element in the plug dropping out???
either way it needs a new piston and sleeve
Yea, sounds like your engine ingested the glow plug element. If the scratches go all the way up the piston past the oil rings, it will cause the problems you are describing. Im suprised the #6 plug did this. this has hppened to me twice with #5 plugs.
If the engine ate the element there is a good chance that it got into the rear bearing and damaged the races as well.
PERROTTO is offline
Old 10-08-2012 | 02:31 PM
  #4249
Lille-bror's Avatar
Originally Posted by Lille-bror
Hi all.
Here is my Team engine - now a lot lighter and lowered CG.
The original Novarossi head weighs 103 gram. The head from my HPI Pro F3.5 HPI part #101589 weighs 72 gram and is lowered a lot (7 mm lower than the Novarossi head). The 4 screw holes have the same position, so why not put the HPI head on my Nova? All it tooked was a little bit of grinding on the Nova house. VOILA the worlds first NOPI engine!
Life is simple!
The engine performed just great during the race yesterday. 10ºC ambient temp and the engine was approx. 100ºC (made only one temp measurement). 9901 pipe, 41001 header and 5,5mm venturi. When I drag raced down the straight alongside a Ninja JX21-B02 engine with 6,5 mm venturi, my car had the same acceleration and topspeed . I don't know if the 41021 header would have made similar performance. Didn't have time to make an comparison during this one day race.
BTW: just got my 4,7 mm venturi... I guess it will test my tuning skills to get the settings right... . Its so different how different engines reacts to venturi sizes: I've no problem tuning Novarosssi engines and my sons old Sirio (Novarossi carb) engine with a 5,5 mm venturi. On my practise engine (STS D21T with Novarossi carb) anything smaller than a 6,5 mm is impossible...
Lille-bror is offline
Old 10-08-2012 | 03:04 PM
  #4250
Originally Posted by mjealey
It is not bc CRE P5 ran 30 minutes straight in the main. OS Speed .19 & .21 ran fine for 4 tanks of fuel each early in the morning in practice. New lines, filter, tank is on the buggy.....
Be sure to check your pipe as someone has already suggested. If the pipe has any restriction , the restriction will be at the smallest point, most likely at the exhaust press port. When your tank has more fuel in at, like at the first of the run, it may not take as much press to push fuel to the engine. 4 minute is you have less fuel, more air, fuel may require more pressure. Exhaust port on the pipe may not be completely closed, but may be clogged enough to reduce your pressure and cause a problem. Just a theory, but I've cleaned a lot of pipes and you would be surprised what comes out!
BPettit is offline
Old 10-08-2012 | 05:40 PM
  #4251
mjealey's Avatar
Yep, I thought of that. Ran it on 3 pipes. An OFNA 086, Nova 9886, and a brand new never ran before OS 2090. Did it on all 3 pipes. Other 3 buggy engines will run all day and night with all the same parts. I am getting ready to tear it down here in 30 minutes actually. I will take pictures tonight or tomorrow morning.
mjealey is offline
Old 10-08-2012 | 06:20 PM
  #4252
Suspended
Did you try the P5 carb?
rcuser567345 is offline
Old 10-08-2012 | 07:17 PM
  #4253
mjealey's Avatar
I have not had time tonight. I am tearing the carb on hte plus-4btt apart right now and trying to see of I see anything. Will post pics in a little bit....
mjealey is offline
Old 10-08-2012 | 07:49 PM
  #4254
mjealey's Avatar
ok, so I took everything apart and have some pictures. Everything looks really clean. The carb looked good and the orings look brand new. Flushed the whole carb out with denatured alcohol and some air. No dirt came out and looks as good as new. The piston and sleeve looked pretty good, no signs of cracks, sleeve is really smooth, etc.... I have a picture of the farthest i could push the piston up the sleeve and is really tight at the top still.
The only thing I saw that might cause a problem is one of the shims on the head button was a little rough looking. I had some shims so I put new ones on it and at .80 for now as I do not have the shim to go .70 right now. Maybe not sealing good and the top of the sleeve is a little nicked but it ran fine for 3 race weekends like that. I am going to put it back together and go to the track Wed. night and bring the carb on the P5 and see if it does it or not and switch to p5 carb if it does.Pictures are not the greatest but hopefully it helps.
mjealey is offline
Old 10-08-2012 | 08:35 PM
  #4255
PERROTTO's Avatar
You may need to resurface the top of the sleeve. Looks like there are a couple deep scratches there.
PERROTTO is offline
Old 10-08-2012 | 08:39 PM
  #4256
mjealey's Avatar
Yeah that is what I was thinking after looking at it but all is well for the most part.
mjealey is offline
Old 10-09-2012 | 04:54 PM
  #4257
mjealey's Avatar
Well, I believe I have found the problem...... What is the chance of getting a bad 17011 bearing from the factory. I looked at things a lot closer after I put the engine back together and i noticed some play in the bearing. I am not talking the crank moving front to rear a little as that is normal. I can take the crank and move it up and down to speak in the bearing. I can turn the crank and the inner race does not move. Like the crank has wore down or the race is too big in the bearing. As soon as I put it in I did the motor clean test and it passed. I noticed oil on the bottom of the engine while tearing it apart but I also had a fuel guy spill fuel while "playing" with this engine at the track. The crank looks fine and perfectly smooth feeling and looks fine but does not begin to fit correctly in the inner race of the bearing.
I went and looked at the CRE P5 I have and the new bearing in it is super tight and I have none of that play and it runs fine and never flames.
What are the chances of getting a new bearing that is out of tolerance bc I think I might have.
I honestly have no more than 10 minutes on this bearing since I had to pull the engine and put something in that would run for the mains.
Coincidence or not?
What should the measuremant of the crank be at where it meets the front bearing? I would like to measure just to check if it is the crank?
mjealey is offline
Old 10-09-2012 | 05:31 PM
  #4258
hambone's Avatar
Bingo! 17011's got really crappy. They were really good, then got really bad. Our local hobbyshop has a huge track that draws many racers and can't give those bearings away.
hambone is offline
Old 10-09-2012 | 05:33 PM
  #4259
mjealey's Avatar
Originally Posted by hambone
Bingo! 17011's got really crappy. They were really good, then got really bad. Our local hobbyshop has a huge track that draws many racers can't give those bearings away.
I had heard grumblings about this, but at the same time I have heard these are still the best bearings on the market. It sucks to be out $30 but sometimes the hassle is not worth it trying to get them to do something about it. I think I will roll with a $14 TKO. Put one in my Speed and has been very good!!!!
Well this sucks.....
mjealey is offline
Old 10-09-2012 | 05:48 PM
  #4260
Suspended
At least you found the problem, I have TKO ceramics front and rear, they are excellent bearings, long life and high quality.
