NOVAROSSI Engine thread....
#4996
Hello,
I am running a P5 with a C6 plug. My problem is priming the tank after it has run dry. If I run out of fuel and refil the tank, I block the exhaust port and open the carb for the fuel to refil the line however the momnet I let go, the fuel shoots back into the tank. I have to keep my hand on the exhaust for a long period until it starts up again. Once the air is out, it runs perfect. You can see when i prime how the fuel and bubbles bounce up and down the fuel line as it turns over the starter box. If I diconnect the fuel line from the carb and hold the exhaust the line pressures immediately, I then pinch the line and reconnect the carb but as I let go, the fuel shoots back into the tank. The motor runs around 120 / 130 degs C (250-265F) and im running 25% nitro. My other motors used to prime fast and never had this issue before. Any ideas?
#4998
Don't you think if it was a leak it would do it at any temps? I used to per heat to 80 degC before starting but it would battle to prime. If I pre-heat to 50 degC it would start no problem. It's as though the heat from the motor is preventing the fuel from entering the carb.
#5002
Considering a new P5 in my truggy. I've heard good things about it for truggy use. What's the latest on P5 bearings? I thought I read that the new P5 XLT comes with decent bearings that don't need to be replaced. Is that true?
Don't feel like spending extra $$$ on bearings for a new engine. And how do you like it in a truggy?
#5003
#5005
#5006
The newest P5's have the 17011 front brearing installed now. It's about time, however, the rear bearing uses smaller balls and seems to be decent although I would replace it with a ceramic or better quality Nova steel bearing just to be sure.
#5009
352Likes
