Like Tree352Likes
NOVAROSSI Engine thread....
Old 02-04-2013 | 06:14 PM
  #4981
hookem34's Avatar
R/C Tech Elite Member
Originally Posted by copey70
Hello everyone, you all helped me with my first question, I appreciate those who chimed in. I'm still walking the path of learning to tune my Bonito .21. I read someplace or was told, I don't recall which so I'm hoping someone can set me straight on my next question. Here it is, if the idle doesn't came back to down to it normal setting fairly quickly and hangs high for a second or so I'm lean on the bottom end right ? Learing all this 1/8 of a turn here 1/4 turn here can really leave me scratching my head at times That's half the fun of it most of the time. Thanks again for any help !
If your engine is fully broken in (about 2 gallons on a Nova) and your idle momentarily hangs after a WOT pass then settles into a smooth purr, your actually a tad lean on top. Richen your HSN just a hair and repeat the WOT.
If the idle hangs for more than 20-30 seconds after a WOT pass then your idle gap is to large. Lots of variables to consider. If you really listen to your engine it will tell you immediately what needs adjusting. Just takes some practice.
Keep in mind that your bottom may become rich if you have to really richen the top. You may need to lean your LSN a bit after you get your HSN dialed in.
hookem34 is offline
Old 02-04-2013 | 06:52 PM
  #4982
rubiconon37's's Avatar
Just got 2 plus 21 4 c's. those of you who have this motor what is your prefered break in method? Thanks in advance.
rubiconon37's is offline
Old 02-04-2013 | 09:05 PM
  #4983
Timox's Avatar
if the idle doesn't come back down to a normal setting fairly quickly and hangs high for a second or so I'm lean on the bottom end right ?
No thats a ritch bottem end if i'm not mistaken. Keep leaning the bottem end till the idle stays high. Then readjust your idle back to a normal idle speed.
Timox is offline
Old 02-05-2013 | 01:29 AM
  #4984
dirtdog's Avatar
Hello all, I have a 21 4c ceramic that has about 8 gallons on it. The engine still runs good and has plenty of pinch. I want to send the motor in for a refresh and was just curious to what other people do when they have that many gallons on there engines. Can i expect the same reliability and longevity? Do i even need to send it in? I just want to be prepared for the upcoming season without any issues. Thanks in advance. Tim
dirtdog is offline
Old 02-05-2013 | 11:57 AM
  #4985
GMS_Racing's Avatar
Anyone had there hands on a 21-7 keep off? Wondering about pipe recommendations.
GMS_Racing is offline
Old 02-05-2013 | 12:31 PM
  #4986
Adam Drake's Avatar
Timox- You are correct.
dirtdog- I would keep running it.
GMS Racing- I use the 41021 header and 9901 pipe with the Keep-Off 7.
Adam Drake is offline
Old 02-05-2013 | 01:46 PM
  #4987
copey70's Avatar
Thanks for the info, I was doing it backwards than. The motor was broken in and ran for two races, than sat for a year before I bougth the car. It runs good, I'm just trying to learn how to tweak and tune it, if I get it too far out of whack I just go back to factory settings and start over Thanks again for the info !
copey70 is offline
Old 02-05-2013 | 01:48 PM
  #4988
copey70's Avatar
That makes sense... thanks !
copey70 is offline
Old 02-06-2013 | 01:33 AM
  #4989
Originally Posted by Maximo
runtime usually comes from how good of a tuner/driver you are, and how lean your willing to run the engine........You can get great runtimes from almost any engine if you know what your doing, modified or stock.....
As for your other question it really depends on what you consider modified...Against what was traditionally called " modified " in the industry my Clocked engines are quite different...Generally speaking the traditional modified engines the work is focused around smoothing out the flow pathways of the mixture, adding guide channels to the exterior of the ports (Fangs,scallops etc ), turbo scoops on the crank face, polishing the sleeve...Usually very visible to the naked eye........ My Clocked engines have almost no changes you can see with the naked eye, as all my work is focused on the ports themselves, altering not only the port timings but also the port angles and volumes...Pretty much unless you know what you are looking for my work is almost invisible.......Far less impressive to look at then "Traditional" mods..........However in terms of affects on performance my style of modifications deliver far more radical changes to the engine, with far greater gains in both power and RPM........Of course this is all relative to how you define the terms.....
Thanks for the explanation. I live in asia, otherwise, I'd love to try your clocked engines...
blaushark is offline
Old 02-06-2013 | 04:01 AM
  #4990
Maximo's Avatar
Living in Asia makes for no issue, I send engines everywhere with no issues ! including Asia !
Maximo is offline
Old 02-06-2013 | 06:00 AM
  #4991
Maximo's Avatar
he is correct ! the very first signs of a lean HSN is hanging idle after a WOT pass.....Usually it happens when you are only slightly lean, you have enough fuel for full power, but not enough to idle down correctly..............Also too much idle gap can cause that, and so can a lean LSN.....
Maximo is offline
Old 02-06-2013 | 04:02 PM
  #4992
nickdawg18's Avatar
I can't wait till I get a keepoff! Maybe even a clocked one!
nickdawg18 is offline
Old 02-06-2013 | 04:05 PM
  #4993
xc7's Avatar
xc7
Still a couple weeks out but we will have them both in stock soon...
xc7 is offline
Old 02-06-2013 | 04:19 PM
  #4994
nickdawg18's Avatar
That's all fine by me!!! Just can't wait to see it in action. I heard its one hell of an engine!
Old 02-06-2013 | 04:22 PM
  #4995
22Racer's Avatar
When I rebuild an engine the first thing I look at is the crank. If the crankpin is not worn too bad then the engine is usually worth rebuilding. If it needs a crank then it can get fairly costly to rebuild but sometimes still worth it. Send me a pm or e-mail me at [email protected] and I will get you a price.
Rex
22Racer is offline
