Like Tree352Likes
NOVAROSSI Engine thread....
Old 02-17-2013 | 05:52 PM
  #5026
shimano's Avatar
Originally Posted by merdith6
I told me this. The most recent P5 I got from the distributor had it installed.
The parts list on novarossi site has them listed as 17011
http://www.novarossi.it/2012/images/...a/S21P5XLT.pdf
shimano is offline
Old 02-17-2013 | 06:15 PM
  #5027
CKmaxx's Avatar
They list 17011 for the Roma, too and it's not supposed to have it either....
CKmaxx is offline
Old 02-17-2013 | 09:44 PM
  #5028
Timox's Avatar
Default Vapour Lock
Dose anyone here know how to solve a vapour lock issue ?
I have a Plus4 BTT which is only just run in and am having problems with vapour lock where if the engine stopes or runs out of fuel and when you go to restart it there's just no way. It wont even fire at all. The fuel just gets to the carb nipple and shoots straight back.
Funny thing is its not like its too hot either. I put my Exergen temp gun on the carb and it was only showing 185 when it was doing it.
The next run i did ritchen up the top end a couple hours but its still no different with the vapour lock problem.
The engine runs fine out on the track. Great really. Its just if it ever stops for any reason your not gona get it started again for at least the next 15 minutes or more.
Timox is offline
Old 02-17-2013 | 10:13 PM
  #5029
rsawyers9's Avatar
I've been having an issue with my p5. I've got about 1.25 gallons through it so far and break in has been fine. My issue is since I have started leaning the motor it flames at the end of the straight as soon as I let off the throttle. It generally happens if I adjust the idle to where it should be. I currently have the idle high just to avoid this problem. It runs fine in the infield and I'm getting runtimes right around nine minutes w/ the 8mm restrictor so I know the engine is not overly rich. Good pop off the corner and good smoke. It's been cold here, down in the 40's, when I've been at the track and the motor is running a little on the cool side ~200. I've tried going both ways on the hsn and the lsn and I get the same result. Should I start over with my needle settings? Could the motor still have enough mechanical pinch to be stalling when I drop the throttle? Thanks for any help.
rsawyers9 is offline
Old 02-17-2013 | 10:21 PM
  #5030
Maximo's Avatar
what fuel and glowplugs do you run ?
Maximo is offline
Old 02-17-2013 | 10:25 PM
  #5031
rsawyers9's Avatar
Running Byron's 30/11 and nova #6
Old 02-17-2013 | 10:33 PM
  #5032
Maximo's Avatar
thats a solid combo, tho depending on your climate a hotter plug may help you some......
is your track conditions dusty ?
Maximo is offline
Old 02-17-2013 | 10:34 PM
  #5033
houston's Avatar
sweeet , I imagine the price will go up a bit but its a great move imo
judging by what merdith has shown and the exploded view which was updated on january 9 of this year , the p5xlt is now dialed!
houston is offline
Old 02-17-2013 | 10:46 PM
  #5034
rsawyers9's Avatar
Yes, track was dusty one of the days. New filters both days out. I may try a hotter plug, but the weather is looking to change for a little warmer here. I also ran new clutch bearings and made sure the clutch shoes were not dragging on the bell. I checked all gear meshes and the drive train is free also. It seems like it flames only after being full throttle with sustained rpm. If I let off slightly and then get back on throttle it doesn't occur.
Old 02-18-2013 | 12:17 AM
  #5035
PERROTTO's Avatar
185 degrees at the carb seems pretty hot. I've overheated the carb warming an engine with a heat gun and fuel would bouce back into fuel line as you described. I could hear the fuel sizzling as it tries to enter carb/carb throat. Still may want to check entire fuel system for leaks or blockage, and check exhaust gaskets also. May also have some gunk in fuel inlet banjo fitting on carb.
PERROTTO is offline
Old 02-18-2013 | 03:08 AM
  #5036
Timox's Avatar
Yeah i did replace all fuel lines and re-routed them just to rule that side of things out.
Just checked the gaskets and found the one that joins the pipe to the pipe manifold was sliced open and had a little bit hanging off it. Was still mostly intact though. I think it must have got too hot and softened too much.
I have put another Novarossi carbi on to try that next. Never had it happen before on other Nova's so will try that next and see what happens.
Timox is offline
Old 02-18-2013 | 06:35 AM
  #5037
sounds of a lean bottom to me.
RePeTe is offline
Old 02-18-2013 | 07:26 AM
  #5038
beidle99's Avatar
I agree with repete. I had a similar issue at a track last summer that had a long straight into a sweeper. engine would cut out as I got on the throttle again exiting the sweeper. Thought it was the HSN and opened that up and the problem was still there. Fattened the bottom end 2 hours and it went away.
beidle99 is offline
Old 02-18-2013 | 02:51 PM
  #5039
EBMods's Avatar
Hello everyone, just wanted to let everyone know we now have Power Plates for some of the Novarossi engines. Please check out the link, and if you have any questions please feel free to ask.
http://ebmods.wordpress.com/2013/02/18/part-pp-3/
EBMods is offline
Old 02-18-2013 | 02:54 PM
  #5040
EBMods's Avatar
Yep check and reset your idle gap and retune your LSN.
EBMods is offline
