Like Tree352Likes
NOVAROSSI Engine thread....
Old 07-23-2012 | 07:25 PM
  #3526
rider313's Avatar
Originally Posted by triplebvalp
Ok, understand the Castor oil thing ... here is a cut and paste from the Power Master fuel web page:
"Ultra-clean burn – Easy to tune - No after-run necessary
Extended runtime that sheds pit stops during long mains
Multi-viscosity 9% lubrication package: Synthetic/Castor
blend w/ high-tech EP package for the ultimate combination of rpm and protection"
What does VP power masters fuel have to do with my post?
rider313 is offline
Old 07-24-2012 | 01:32 AM
  #3527
Losimoe's Avatar
Default novarossi roma
So i just bought a Roma and wondering which pipe is best for it. currently i have a Nova 2096/41021, Jp-4, Losi RE11, Aplus0801.
I remember reading that some like the 9886 pipe.
Also wondering if the Roma came with the new nova carby.
thanks
Losimoe is offline
Old 07-24-2012 | 02:38 AM
  #3528
TIX's Avatar
TIX
i run the 2084/41029 on mine to soften it out a little. Thats what i had on it yesterday at Sunshine if you remember seeing it.
The 2096 will be a good pipe on it with the short header
TIX is offline
Old 07-24-2012 | 10:26 AM
  #3529
"Smiley"'s Avatar
Going to try out a P5. Do I need to change out the Bearings, Or are the stock ones ok?
"Smiley" is offline
Old 07-24-2012 | 10:40 AM
  #3530
Muggydude's Avatar
It's highly recommended you switch out the front bearing for a 17011 bearing.
Muggydude is offline
Old 07-24-2012 | 02:07 PM
  #3531
lennybigblock's Avatar
hello guys, I have a new Bonito and I have 3 pipe RE10, RE11, RE12. I want to know what would be the best with this engine .... I want to know if you try this type of pipe on this engine
Thanks Martin
lennybigblock is offline
Old 07-24-2012 | 02:33 PM
  #3532
TX_Punisher's Avatar
Some guys will break-in on the stock bearing, then after 1/2 gallon or so, make the switch.
Weren't you running Plus 4's?
TX_Punisher is offline
Old 07-24-2012 | 02:40 PM
  #3533
bigjayjay1's Avatar
Thanks Martin
Some like the Re12 I have one need to give it a whirl
bigjayjay1 is offline
Old 07-24-2012 | 04:53 PM
  #3534
"Smiley"'s Avatar
I've been running the plus 4's. Just thought I'd give a p5 a try...
"Smiley" is offline
Old 07-25-2012 | 05:33 AM
  #3535
Maxxed-out's Avatar
What causes the top of the piston to turn black?
It looked like the inside of a chimney.
I was able to clean it and get it off. I usually take apart and clean my motors about every 3-4 weeks and the last time it was done I didn't have this problem.
This is on a Bonito
Maxxed-out is offline
Old 07-25-2012 | 05:41 AM
  #3536
beidle99's Avatar
This is on a Bonito
Its carbon build up from running a little on the rich side. Not a bad thing to leave alone or clean up just dont do near the edge of the piston because it becomes part of your seal
beidle99 is offline
Old 07-25-2012 | 05:43 AM
  #3537
houston's Avatar
This is on a Bonito
Running a fuel with a good amount of castor , it will not hurt anything
Also means your tunes a lil off
houston is offline
Old 07-25-2012 | 05:49 AM
  #3538
Maxxed-out's Avatar
Im running VP powermaster 30%
Is it rich?
Thanks for the help Houston
Old 07-25-2012 | 05:51 AM
  #3539
Maxxed-out's Avatar
Old 07-25-2012 | 07:21 AM
  #3540
kgombe's Avatar
Is it rich?
Just a little rich...any fue with Castor wil give you that effect... You are fine a little toothpaste and a toothbrush works great...
kgombe is offline
