NOVAROSSI Engine thread....
#3556
I'm new to thread and I am looking for some insight ! I just acquired 2 novarossi engines.
1st up is a used 21-5kt, guy claims to have only broken it in with a gallon and half ! I can't turn it over with my hand so the compression is realy tight ! I took off the turbo head to clean it out and I noticed there is NO shims in it ! Downloaded the Manuel and it shows there should 3 shims ! Anyone no for sure ?
2nd is new in the box 2001bf never seen fuel ! Anyone have experience with these ?
Any feedback appreciated !
The N2001bf i think is a 3 port. Does it have a black head on it? If so it is a great little engine, good runtime, decent bottom and a little lacking on the top. A couple guys at my track ran them as there backup motors they ran good with them. The 21-5kt however I dont know alot about but if it is missing shims that might be why you cant turnover with your hand, I would def get the right shims in there before you run it.
#3559
But the temps are like 300 once the top is leaned to make it run right so would that not be more like a lean bottom??...Also changing the front bearing is like $30 but that rear is like a $150 bearing
I think I am going to be able to make it Sunday so we can check it out
#3561
#3562
#3563
Wow a 4.7mm venturi, that would be fun to tune.
http://www.novarossi.it/eng/news/read.php?newsid=191
#3564
#3565
if you ran the new carb with the 5.4 inserted you may think differently.. no power loss.. temps were the same.. but only a slight increase in runtimes.. nothing to warrant getting the new carb.. these inserts maybe only intended for the new carb.. which become standard on nova engines soon...
#3569
Many Danish drivers runs 7 mm in their RB and SH engines and gets +9 min of runtime - the same as I do with my Nova Plus 4 Team with 5,5 mm venturi.
I'm gonna try try both 4,7 and 7 mm venturies to see the difference
352Likes
