Like Tree352Likes
NOVAROSSI Engine thread....
Old 10-21-2022 | 05:05 PM
  #10996
petersen114's Avatar
Originally Posted by wely324
Really cool to see that basically novarossi will not be gone forever, hopefully some new engines soon!
Nova has been testing off-road engines lately.
sn47som1 and Jaredf like this.
petersen114 is offline
Old 11-18-2022 | 02:25 AM
  #10997
Anyone know the part number for Adam drake 5tcl nova piston, rod, sleeve. Hope to find online.
silence360 is offline
Old 11-18-2022 | 04:43 AM
  #10998
cansoykal's Avatar
Can't you just use just about any other 16.26x16.80mm Nova piston sleeve kit for that 21 plus crankcase?
cansoykal is offline
Old 11-18-2022 | 06:52 PM
  #10999
Looks like the P5 will work then if that is the bore and stroke of the 5TCL. Thanks!!
Old 11-19-2022 | 01:54 AM
  #11000
Roelof's Avatar
I believe the Drake does use the RB conrod, that has a slight bigger crakpin, but the standard R7 rod can be made to fit easily.
Roelof is offline
Old 01-11-2023 | 09:55 AM
  #11001
Suspended
Are old novarossi plugs different than new style plugs. I installed a protek turbo plug in my p5 and it leaked around the threads.
MXRCF1 is offline
Old 01-11-2023 | 07:09 PM
  #11002
Isn't the Protek an O.S. based engine?
Cardiak is offline
Old 01-11-2023 | 07:11 PM
  #11003
kgombe's Avatar
The first run was Novarossi based.. but I'm thinking he used the OS version
kgombe is offline
Old 02-13-2023 | 06:50 PM
  #11004
Default Compatibility infos
Hi, i have an old jp racing eagle b.5 (fx crankcase), and i have seen, if my memories are good that the novarossi p5 piston/sleeve are the same, can someone tell me if it is right?? I am looking to rebuild it. Any info and advise on this will be appreciated...
kaven turcotte is offline
Old 03-14-2023 | 08:06 PM
  #11005
rcmania74's Avatar
You want the protek T series plugs
rcmania74 is offline
Old 04-13-2023 | 11:42 PM
  #11006
Captain Howdy's Avatar
Hi, does anyone happen to know if you can run 16% Nitro in a Novarossi .21 Keep on engine? I've read before you can adjust with shim removal, but I'm not sure how many need to be removed. I know the Mephisto engine includes a 28038 button head for running 16% and recommends purchasing a 28025 button head for running 25%. I'm wondering if the same applies to the Keep On engine which comes with a 28025 button head. Not sure what to do since they banned 25% nitro here in the EU.
Captain Howdy is offline
Old 04-14-2023 | 01:00 AM
  #11007
Roelof's Avatar
Any engine configured for 25% will run fine on 16%. Do you want the best out of it, then you need to remove 0.1mm headshim.
Captain Howdy likes this.
Roelof is offline
Old 05-18-2023 | 07:43 AM
  #11008
Default Novarossi Keep On .21 Running reversed
So I haven’t run my car for over a year. The car was stored properly, engine oiled, clutch removed etc.. tried to run it for the first time today and the engine is running backwards. I’m confused because I haven’t changed anything, yes my fuel is over 1 year old but was still sealed and stored properly, also tried a different fuel and new glow plug and same issue…so frustrated right now. About to give up on it 😩
Old 05-18-2023 | 07:45 AM
  #11009
make sure your diffs are installed right that could be the issue and the engine could be running fine.
wely324 is offline
Old 05-18-2023 | 08:07 AM
  #11010
Can’t believe this… right after my post I went back out and reset my carb needles and all is good.. 😎
