Like Tree352Likes
NOVAROSSI Engine thread....
Old 07-18-2012 | 04:38 AM
  #3466
chicky03's Avatar
Originally Posted by yoggyong
Thx for the inputs!
My power lacks in the bottom. Actually, its already good enough but just that itching feeling for more since truggy could be pushed more. Top is good. My friend runs a bonito on a truggy as well. And he advised me on getting a 9886 pipe with it. Before I jump on it, I want to know what are the different choices I might have on here with advises from the experienced racers.
Fuel mileage here is important as well for me. I'm running 10+ mins on a truggy with a 30min finals. Any less would result in an additional pit-stop.
Running stock mugen clutch. Alu shoes with 1.0 springs.
The 9886 pipe is more top end but more over all power. I don't think that is what you want. I'd get an m2c clutch and use hard shoes with yellow or black springs. The stock mugen clutch comes in too early and bogs the engine down.
chicky03 is offline
Old 07-18-2012 | 07:58 AM
  #3467
houston's Avatar
Mugen shoes are HEAVY with alot of surface area
Use 1.1 springs
houston is offline
Old 07-18-2012 | 09:23 AM
  #3468
Originally Posted by ben73
yes a 3 shoe is more aggressive but you will find that you can achieve better runtime with the 4 shoe setup. You tend to put the power down more efficiently and don't light up the tires so much. Is it that the engine does not produce the punch or are you not able to put the power down and hence you feel its the engine but its actually the tires/chassis?
If its putting the power down then stay with 3 shoe as it will be more aggressive.
Interesting cuz I always thought it was just the opposite using a 4 shoe. Im debating getting a Buku which is a 3 shoe or the m2c 4 shoe. Whats your thoughts on these 2 clutch set ups? I currently run the stock AE 3 shoe set up which is decent but the shoes dont last long enough for me.
rcmoe is offline
Old 07-18-2012 | 02:09 PM
  #3469
megasaxon's Avatar
a big thing to think about when talking shop about your clutch setups is realizing the weight of yours shoes vs the spring you run. for example:
Stock Team Associated clutch, 3 shoes, running 1.0mm springs. in a buggy
Ascendancy 4 shoe/Werks 4 shoe running 4 alum shoes and 4 .9 springs
They actually have a similar stall rpm because all 3 shoe setups have larger, heavier shoes over a 4 shoe setup, so for a 4 shoe setup, you need less spring tension to hold the shoes in when inertia is applied.
I personally run only 4 alum shoes and .9 springs on my Ascendancy and Werks clutch setups, and i also like the "Light" Werks flywheel(Ascendancy's standard flywheel is roughly the same weight).
megasaxon is offline
Old 07-18-2012 | 04:42 PM
  #3470
erc55's Avatar
The compression on a bonito xlb should last how many gallons? Running byron 25/9%.
erc55 is offline
Old 07-18-2012 | 04:54 PM
  #3471
rider313's Avatar
How good can you tune? 8 gallons isn't out of reach.
rider313 is offline
Old 07-18-2012 | 05:33 PM
  #3472
JEDI BASS's Avatar
Just ordered the Hudy bearing tool and another 17011 in case that's what's causing my flameout issue. We definitely have dusty track issues here in TN what with the 100F plus temps during June and July.
JEDI BASS is offline
Old 07-18-2012 | 05:58 PM
  #3473
houston's Avatar
dont forget to use something to keep tool from pressing on the inner race for installation , you will ruin the bearing
houston is offline
Old 07-18-2012 | 06:40 PM
  #3474
lennybigblock's Avatar
Originally Posted by lennybigblock
you have no idea??
merci pour vos réponse ... manger du caca
lennybigblock is offline
Old 07-18-2012 | 07:37 PM
  #3475
houston's Avatar
Thank u for ur responss .....eat poop ?
houston is offline
Old 07-18-2012 | 07:40 PM
  #3476
rider313's Avatar
Haha
rider313 is offline
Old 07-18-2012 | 09:26 PM
  #3477
yoggyong's Avatar
Originally Posted by Muggydude
Yes. All of those engines come with it anyways.
Definitely get the 2058 for more bottom. Really opens the engine up. The 2096/9901 actually seam to restrict it. Fuel mileage is pretty darn good with the 2058 as well.
If you really wanted to add some bottom pick up a 2013 pipe. Maybe 30 or so seconds less runtime than the 2058.
I suppose u mean the werks 2058? And 2013 I suppose u mean the orion?
yoggyong is offline
Old 07-18-2012 | 09:28 PM
  #3478
JEDI BASS's Avatar
Any recommendations? I have never done this before and really don't have much experience since I'm still a newb w/ only a few months (had a long layoff in the middle) experience w/ RC.
EDIT--- nevermind, I get it
Old 07-18-2012 | 09:33 PM
  #3479
yoggyong's Avatar
More top end and overall power? At the expense of mileage? If not, it shld just be a better pipe on a truggy?
Use 1.1 springs
Good tip on here Monty! Shld try changing springs than pipe! The disparity in costs is way too much!
yoggyong is offline
Old 07-18-2012 | 09:41 PM
  #3480
yoggyong's Avatar
yes
be careful, rear bonito bearing is different size
Good point to note!
Hey Ben, I'm pretty sure it's abt putting the power down. The truggy itself is much heavier than bugs. And I don't seem to experience much wheel spin unless I'm frantically trying to catch up on lost time and driving with a crazy mind. I run the mugen 3 shoe clutch on truggy and the werks heavy 4-shoe (from who u know ) on my buggy.
Another thing I just realised could be my restrictor! I'm running on a 6.5! I would try changing springs to 1.1 and restrictor to a 7 before investing in a new pipe!
yoggyong is offline
