Like Tree352Likes
NOVAROSSI Engine thread....
Old 09-27-2012 | 08:37 AM
  #4126
So the grand solution to the "plug dilemma" is, you can run OS plugs if you start and stay with them(and you may even have a better idle and wider tuning window), but you can't switch back to non-OS plugs once you've had one in. Everything's clear then.
Herrsavage is offline
Old 09-27-2012 | 08:56 AM
  #4127
houston's Avatar
EXACTLY
houston is offline
Old 09-27-2012 | 12:32 PM
  #4128
kgombe's Avatar
the proof is in the pudding...
i guess...
kgombe is offline
Old 09-27-2012 | 07:38 PM
  #4129
houston's Avatar
i guess...
mmmmmmm pudding
pistachio please
novarossi rocks!!!
houston is offline
Old 09-27-2012 | 08:51 PM
  #4130
Originally Posted by houston
21 = 29
20 = 30
Damm it
I got it wrong
Hi uwikz you go for next nats??? GL
yollie is offline
Old 09-27-2012 | 09:10 PM
  #4131
@uwikz ahahha you love that nova price too. But keep the old carb instead the new one. 10$ cheaper and headache free ahahaha.
I got rust in my crankshat. Can I use rust remove fluid to clean it? I'm not sure it safe or not? There's no coating in 4btt with bad fuel and bad maintenence mine get rusted in 3 days after race
yollie is offline
Old 09-27-2012 | 10:49 PM
  #4132
bigjayjay1's Avatar
You can take the crank out and clean pickup a can of corrosion x Granger sells awesome stuff. Its a excellant lubricant and it binds to metal it also clean the internals. I started using cause my Werks engine would rust so bad it started to flake this stuff cleaned my internal, stopped all rusting while lubricating its save on a ramped crank also.
bigjayjay1 is offline
Old 09-28-2012 | 12:57 AM
  #4133
Lille-bror's Avatar
Default REDS has a spy in the Novarossi thread!
Read this article from Neobuggy:
REDS "41001" header
Reds Racing new Manifold
Engine specialists Reds Racing have announced the release of a new 'double bend' manifold, designed by their R&D department, in cooperation with REDS' Team Drivers. The new polished mainfold doesn't only look great, but more importantly has a function - improving fuel economy, additionally it provides a very smooth and manageable powerband which in particular suits mid to low grip tracks, the result evident in laptimes. The manifold can be used with all and any of Reds' pipes - EFRA 2099, EFRA 2069 and the EFRA 2034. Available now, part # CL210091.
Looks similar to Novarossi 41001
Lille-bror is offline
Old 09-28-2012 | 01:06 AM
  #4134
Lille-bror's Avatar
Originally Posted by Lille-bror
Here in Denmark we mostly have to use EFRA approved pipes (3 chamber). I run the 9901/41021 combo on most tracks. But at one specific track the 9901/41001 combo is GREAT, because you don't need too much bottom, and you can use the extra top on the long straight. I know Monty likes the 41005 better than the 41001
This was actually what I wrote about the 41001 header two years ago...
Old 09-28-2012 | 04:06 AM
  #4135
blade954's Avatar
Yep we are the same here in OZ EFRA pipes only at sanctioned events and since i run most of them i wont wast my time with a pipe not on the list....
I chop and change between 2096/9901 but mostly run the Mugen short Nova header on the XB9 (just keeps every thing in the middle) but some times put the 41001 depending on track conditions....
blade954 is offline
Old 09-28-2012 | 04:40 AM
  #4136
hookem34's Avatar
R/C Tech Elite Member
Cider vinegar.....drop your crank in it for 30 minutes and ALL the surface rust will be gone.....
hookem34 is offline
Old 09-28-2012 | 03:27 PM
  #4137
TX_Punisher's Avatar
You beat me to it.
TX_Punisher is offline
Old 09-28-2012 | 04:24 PM
  #4138
scrapsz's Avatar
Originally Posted by aznitronut
Those were the pipes we ran on the RB WS7's ten years ago, we also used an exhaust adaptor, a guy fro Cali came up with, his name was Don Waller, he had a son that raced, they were good freinds with Bobby Tillman, when he was still racing.
They probably quit selling them, because they were not cheap, 10 years ago they were over a 100 bucks, think about 140ish?
Ahh the good old 'Waller Power Adapter'...damn I remember this combo so very well circa 2003. RB WS7 w/9886 and 41001 with the Waller in between the pipe and header. Holy balls those we some of the loudest and fastest engines I ever drove! They also drank fuel at an astonishing rate. 8 mins was about impossible unless it was running 300 and then is was so ballistic one could barely keep it on the track. The 9886 is still a fuel hog today compared to the 2096 and 9901. But there is nothing like the sound of a 7 port with 9886 way up on the pipe. BRAAAAAAAAAAAAAAAAAAAAAAAAAAP!
scrapsz is offline
Old 09-28-2012 | 07:21 PM
  #4139
My crank also has rust, I was wondering if white vinegar would work as well. Or is cider vinegar the only way the rust will go? Also what's the cure for a loud pipe or is an engine that is breaking in louder than usual?
fung_kyle is offline
  #4140
Is the 2096 a better choice for the plus4 over the 9901? What will it do for me over the 9901. Thanks.
JoeC is offline
