Like Tree352Likes
NOVAROSSI Engine thread....
Old 09-30-2012 | 04:36 PM
  #4156
Originally Posted by mjealey
Hey guys, I have a Plus-4btt that has been absolutely bullet proof and been running fine for about 4 straight weekends until yesterday. I am running A Werks #6 plug in it with the stock Mugen clutch with the same OFNA 086 pipe I have been running this combo for 2 months. I have about 4 gallons on it. I was 4 minutes into the second 5 minute qualifier. I really have not touched the needles besides an hour here and there on the HSN each weekend and no flameouts over the last 2 months. The track had a long stretch and we twist the motors pretty good but all of a sudden the thing will die as soon as I let off the gas at the end of the straight 4 minutes into the heat. Motor was running perfect, nice and crisp, and only about 255 when i temped it.
I richened the top up a little bit, set it down to get 1 last lap in, made the whole 40 sec. lap and once again at the end of the stretch same thing when I let off the gas it just dies.
Repleced the plug and richened the LSN and increased idle gap, did the same thing in the 3 heat except earlier and in the 1st lap. Only dies at the end of the straight from being wide open for a good 3 to 4 seconds and then letting off to make sweeper curve? Idles fine, sounds great but keeps dying? I did not check it at the track, but maybe guessing front bearing? Need to tear into it tonight or tomorrow any ideas? We tuned on it the whole 3rd qualifier and the same thing no matter what we did. Also tried a #5 (hot) plufg and still did it?
Any ideas besides bearing or what would cause it to die after wide open throttle would help?
about a month ago, a friend of mine had the same issue with his nova. It seemed to run good and idle good but flamed at the end of the straight. He just changed the front bearing so he knew that was fine. Changed the glow plug from a nova 6 to o.s p4. Fixed it, ran awesome. Some say that it will harm the head button but he hasnt had problems and the engine is just more reliable. Last week we raced at gas champs where he helped out some others with nova 4btt's that had flame out problems all weekend. Changed to p4's and they ran good and didnt flame. something to try.
Dillon71 is offline
Old 09-30-2012 | 04:51 PM
  #4157
beidle99's Avatar
Try to richen your LSN some more. My btt was doing the same thing. Ran fine on my regular medium sized track but when I went to a larger track with a much longer straight it would flame out when I got off the trigger at the end of the straight to turn.
beidle99 is offline
Old 09-30-2012 | 04:54 PM
  #4158
Maximo's Avatar
check for dirt in the front bearing........ remove the bearing, pull the shields and do a rinse test on a white paper and see if any dirt flows out......Your at 4 gallons and my guess is your engine needs a little TLC..she probably has a little wear and tear that needs to be addressed...
Maximo is offline
Old 09-30-2012 | 04:56 PM
  #4159
mjealey's Avatar
I am going to tear into it here in a little while. I have the 5 out of 6 race in a points series this weekend and want to get that engine running so I am going to order a new bearing and maybe a new rod, replace and see what happens. We really played with it for a few minutes at the track and richened it up quite a bit and the LSN if I remember correctly and still did it but I might be wrong. I am going to tear it down in a little while and see if I see anything in it. I have thought about trying an OS plugs since I have plenty but as a last resort.....
mjealey is offline
Old 09-30-2012 | 04:57 PM
  #4160
Suspended
Check your front bearing. Start the engine, spray nitro spray behind the flywheel at the front bearing, if it shuts off immediately, you have a bad front bearing and that is most likely the problem. Also, check your rear bearing for excessive play.
rcuser567345 is offline
Old 09-30-2012 | 05:27 PM
  #4161
PERROTTO's Avatar
^what he said...just don't spray it directly onto the case as the sudden change in crankcase temp will cause it to die as well.
PERROTTO is offline
Old 09-30-2012 | 06:01 PM
  #4162
mjealey's Avatar
Ok, the front bearing test failed for one. So I pulled it apart and it looked clean inside and the piston and sleeve look really good. Motor was still pretty difficult to turn over by hand. Clean as a whistle inside but I will pull the bearing tomorrow to see if any fine dirt has made its way in. I think the bearing leak had just started and relatively small.
Secondly, I get the bone head of the year award. I pulled off the air filter assembly and there was no venturi in it! I pulled it all off and cleaned everything and I guess forgot to put the 6.5 venturi back in it. That is the dumbest thing I have ever done. My problem was 2-fold. Front bearing starting to leak and a dumb #$% human error. It was tuned for 6.5 and didn't have it in there so no wonder it was lean. It was not lean bogging though and running great until it flamed once you let off the gas. Anyway, I need to get a bearing and replace it before this weekend. I think I should be good. I feel confident after looking at it everything is okay just a really dumb user error I will never make again!!!
New rule also. All my engines get new bearings no question asked every 2 gallons from here on out, maybe overkill but that is what I am doing.....
mjealey is offline
Old 09-30-2012 | 06:13 PM
  #4163
Suspended
Make sure your rear bearing is nice and tight with no excessive play as well.
You can go 3 gallons on bearings, if not 4 or 5.
Old 09-30-2012 | 06:21 PM
  #4164
mjealey's Avatar
I did, real nice and smooth with no play but I am thinking about replacing it too....
mjealey is offline
Old 09-30-2012 | 06:56 PM
  #4165
Suspended
You don't have to replace it if its nice and tight.
Old 09-30-2012 | 08:16 PM
  #4166
bigjayjay1's Avatar
Are you saying you should replace a rear bearing by the three to four gallon mark cause they normally last that long. What type of motor preventable maintenance do you do and how often do you change your rod and bearings. how do you determine if they are out of specifications.
bigjayjay1 is offline
Old 09-30-2012 | 08:46 PM
  #4167
merdith6's Avatar
Default Bearings
The front and rear bearings last forever. I've been running Nova for a long time and have only had one front bearing go out on a p5. The dual sealed Nova bearing is really tough and so are the rear bearings. If you take apart the engine every few gallons and clean it really good then it sould last a long time. I have engines that have been resised, or had a new p/s installed and those bearings never caused any issues with tuning.
merdith6 is offline
Old 09-30-2012 | 09:02 PM
  #4168
Maximo's Avatar
the bearing life is directly related to the conditions the engine is run in..if you run in dusty conditions, especially fine dust, the bearings will need to be changed much more often then someone who runs in a clean environment......17011 is an awesome bearing, but it will not fully protect you in some conditions, dirt will still pass thru it......... So if you run in dirty conditions change your bearings often....
Also engine RPM will play a huge role in how long the rear bearing lasts...If your run a moderate engine on a medium track your likely never going to have any issues... However if you run a high RPM engine on a larger track then your going to see more rapid wear on the rear bearing..especially if they are steel bearings......Bearing life and engine RPM are closely related......A stock steel bearing will last much longer on a 33 000 RPM engine them it will on a 43 000 RPM engine,...... guys who say their bearings last 10 gallons simply do not push their engines as hard as the guys burning down bearings every couple of gallons......... How hard you push the engine and how dirty the conditions you run in are what determines how long the bearings will last............... baby the engines and keep the RPM's down and always run in clean environment and bearings can last the lifetime of the engine..............However take a engine buzz it in the 40K range on a dirty dusty track and you can kill the bearings in 1 gallon with ease.......
Maximo is offline
Old 10-01-2012 | 05:48 AM
  #4169
mjealey's Avatar
Yeah and I admit I like to twist mine pretty good. I run them all 250+ and some 280. The track we ran on was super dusty and huge this past weekend! It was the second time I have been there in the past month so it did it in. A big 150 ft. straight with a sweeping turn before it to build up speed in arid dusty conditions probably did it. Upon further review of the engine it did suck in a little dirt but very little and piston sleeve look ok. I think we caught it early and no damage done to it.
mjealey is offline
Old 10-01-2012 | 09:12 AM
  #4170
Maximo's Avatar
do a rinse out of the front bearing please !!
Maximo is offline
