NOVAROSSI Engine thread....
#5657
The diff btwn the two is the main bearing and the crankcase (area around main bearing)...other than that the engines are the same. I don't have the KO 7xl but I do have a Bonito XLB and the smoothest combo I found was the 2084SS/41021.
#5658
No trick. The rule of thumb is the smaller the insert the more narrow a tuning window. When I've seen the symptom you mention its been too large an air gap with too rich LSN. Check the air gap (0.6mm) and re-tune the LSN especially if the 4 stroking is at idle.
#5659
Hey Nova guys, here is a link to my ad for a 15009T Silicone filled crank - NEW!
Just thought I'd share. Nice upgrade or spare.
http://www.rctech.net/forum/r-c-item...ne-filled.html
#5661
Yes ! it gives the engine more snap, and more top end.........for anyone with a Plus4 or BTT looking for more power should look into the 41001 as well as the 9886........ The difference from a 2096/41021 to a 9886/41001 is like night and day, almost makes it a totally different engine....It is a shame how many people have never seen this engines true potential as they have never run anything but the pipes that neuter the performance.....
and the 9886/41001 give more run time than the 9901/41021 combo.
#5664
#5665
It will definately breathe through the boot. If you put the rubber cap on the intake of a carb, and the one on the fuel inlet, and you rotate the crank so the piston goes up and down, you will see the carb slide move in and out as the engine tries to inhale, so absolutely if you got a hole in the boot it will affect your tune negatively.
#5666
#5669
#5670
I'm ready to try a Novarossi. It will go in my MBX7 or 8ight 3.0 when it arrives.
I have run RB WS7, Ninja B01, old AXE Rossi Cobra. The RB was the best!
So..with budget of $450 for engine and pipe MAX.
P5XLT or Plus21-BTTA Tuned ??
Pipe looks like 2096/41021 ?
Pipes I have: JP-1, JP-4, RE-11
Suggestions please!
Suggestions please!
352Likes
