NOVAROSSI Engine thread....
#5641
2. Rear Bearing: 14.5x26x6mm
Both use NOVAROSSI 7X19X6.3 DUAL RUBBER SEALED FRONT BEARING # NOV17011
We recommend TKO ceramics if you are going aftermarket. Nov17011 for the front.
#5646
#5648
#5649
Hi there I have a bonito 7xl with ceramic rear bearing and have ordered the new keep off 7xl with ceramic rear bearing and was woundering what the difference is between the Two and what pipe people are using to have a smooth power band
#5650
So, another tuned pipe/manifold question.
I'm running a Beat B4 with a 41021/9901 combo. I don't give up anything to anybody on any parts of the track, but I'd like more top end. Switching to the short header should accomplish this, but will there be a noticeable decrease in torque down low? Should I be looking at other pipes?
Thanks.
Thanks.
#5651
Thanks.
Thanks.
putting the 41001 will give the engine more pop across the entire RPM range......I found it gave more snap down low, and a substantial increase in top end MPH.......it may not be as smooth as with the 41021, but withthe Plus 4 engines they can afford to have more kick as they are already quite smooth
#5653
So I switched from a 41021 and 9901 to 41001 and 9886. The new combo gave me the same lap times but with 45 seconds more runtime on a BTTS. The motor seemed smoother, and definitely faster on the top end. Our track doesn't have a lot of room to really stretch out a motor, but it was definitely moving faster at the end of the straight.
#5655
So they're easier to install also, because if you use a pushing tool on the 6.3 it only pushed the centre and destroys the bearing.
So for me there's only pros. The cons would be that some people regard the 6.3mm 17011 as "the best bearing", so that's basicly it.
For me I'd rather have some regular 6's and replace them more frequently, they're cheaper too. (Nova bearing is one million bucks, while you can buy 4pcs 607 2RS of decent quality for $5)
352Likes
