NOVAROSSI Engine thread....
#5506
Clutch is only a half gallon old, so I'm going to sick with it for now. I should find a cheap motor to do some testing.
#5510
That would probably be true in many cases, but in this case the p5's in sale now have a reputation for bearing failure after approximately 2-2.5 gallons, so in this case when the guy says his front bearing is full of gunk, I am quite confident that this is a result of bearing failure and little pieces of bearing passing through the engine.
#5511
#5512
I did a leak down test on the motor the front bearing passed so much air through it I barely had to blow. Guy at the local hobby shop said he had never seen one so bad. And I will not be able to put a pic up of the piston as it and the sleeve have all ready been sent out to get polished and pinched. I ordered Buku front bearing caps to stop this in the future. Or does any body know of a good bearing to replace the stock one for the p5 as I'm going to buy another one in the next couple weeks.
#5513
http://www.amainhobbies.com/product_...-Front-Bearing
http://www.amainhobbies.com/product_...Engine-Bearing
These are the two bearings I have been using with great results on the P5.
#5514
#5518
I just purchased a 21 4 btt wc. My question is i have a pipe combo that i ran on my 21 4c. It is a 41021 and a super strong 9901. The nova site is a little confusing to me. Looks like they changed part numbers around. Will this be a good combo for this motor? Thanks -Tim
#5520
352Likes
