NOVAROSSI Engine thread....
#5476
gday how are you finding runtime with the 9901 ?? wonder what the 9853 with 41001 header would go like??
#5477
We haven't done timed runs and the first final he ran, we didn't attempt long pit stops. He was pitting around 8 minutes and it was only taking around 90cc of fuel in a truggy. That leaves about 60cc left in the tank so he can easily go beyond the 10 minute mark.
We'll know more after this weekend's ROAR event at LCRC raceway.
#5478
As for runtime like Schreff said my engine is still fairly fresh and it already seems like it will be a 10+ engine with the 9901/41021 combo w/ an EB Mods fuel cooler.
#5480
No off-road engines under the Nova label come with filled cranks.
They all run virtually the same and get virtually the same mileage.
The btta has faintly less torque and a touch more top end than the older 4c due to exhaust timing.
Any will be perfectly at home on any buggy.
#5481
This is not completely true, the T-Plus 5 (Novarossi TOP engines) have filled crank, on the other hand they are not so commonly available as Novarossi other engines.
See http://www.novarossi.it/2012/index.p.../t-plus-5.html
#5483
#5487
Hey guys, As my P5 XLT get more and more mileage on it, Im starting to think about new engines. I love my P5, it's such an awesome engine!
As far as decisions go, Im debating between the Mugen B5 and the B4.
It's for an MBX7, BTW with the Losi RE12 system (similar to 9901, 021 combo). how does the B4 compare to the B5 (same as P5) as far as performance and mileage?
#5488
I would stick with the p5 if your looking for something more then maybe look at the crank modded/silicone filled or even a complete mod some reputable guys on here well worth talking too
#5489
I am currently running in my p5 on my hudy break in bench all going well nice engine
#5490
My p5 is toast after only 2 gallons compression is nil and the front bearing leaks very bad. When the piston and sleeve were pulled I found scratches on the back side of the piston and sleeve directly on the exhaust port. I have been very meticulous about air filter maintenance and have never even seen a speck of dust or dirt on the secondary filter. Any ideas on the cause it was not a glow plug element changed the first one after break in and im on my third one now. I'm hopping a polish and a pinch will get me back up and running with a new front bearing. Any help would be appreciated. Oh I run a Mugen MBX6. thanks
352Likes
