NOVAROSSI Engine thread....
#5463
from asking that same question to a Factory driver.. yes thats it.. well the case is different to fit the new rear bearing.. but i was told its practically the same engine..
Don't know the benefits of the rear bearing design though
#5468
No problem, glad I could help. After buying a 2096 pipe I saw an increase of a good 2+ minutes in run time over the 9901 it replaced. I actualy was able to launch harder out of turns too because the low end became slightly softer and didn't produce excessive wheel spin. easier on fuel, easier on tires, and easier to drive fast. If you get a chance to borrow a 2096 try it out, you won't regret it.
#5471
352Likes
