Like Tree352Likes
NOVAROSSI Engine thread....
Old 06-14-2013 | 11:40 AM
  #5686
Originally Posted by t0p_sh0tta
So, I'm looking for a 2096 pipe. Any difference between these two other than the reinforced stinger?
http://www.absolutehobbyz.com/produc...oducts_id=6123
http://www.absolutehobbyz.com/produc...ducts_id=13917
Yes, the one with the brace on the stinger is made from thin, butter-soft aluminum, and the one without the brace on the stinger is made from thick, solid aluminum.
The one with the brace on the stinger needs it because it's so soft that if you press your thumb on it, it will turn into a taco-shell.
In case you wonder, yes, I did make the mistake of buying the one with the brace on the stinger, thinking it was the same. But alas, they are nothing alike except for the efra number
Eivind E is offline
Old 06-14-2013 | 12:05 PM
  #5687
t0p_sh0tta's Avatar
Thank you sir.
t0p_sh0tta is offline
Old 06-14-2013 | 08:59 PM
  #5688
aussies1129's Avatar
Originally Posted by Lille-bror
Hi.
Will it be possible to use a crank from a Plus4T (15010) in a BTT that uses a 15007T crank? Thanks
haven't tried it but I remember reading a post on here way saying there not compatible
aussies1129 is offline
Old 06-14-2013 | 11:53 PM
  #5689
houston's Avatar
Hi.
Yes Bjarne , they even have same timings
houston is offline
Old 06-15-2013 | 06:44 PM
  #5690
whoops must of been something else ??
weird how they have different part numbers??
Old 06-15-2013 | 11:06 PM
  #5691
Lille-bror's Avatar
Thanks a million, Aussie and Monty
Then I'll rebuild one of the nearly worn-out BTT's I got from a friend, I do break-ins for.
Got a 3 gallons (4,97mm north/south) old crank from the Plus4C Team engine with the defective head button, a new R7 rod in the pitbag and an 1 race old AVID bearings set in another engine case. The P/S has very little compression ratio but is without any scratches, so I'll send it to Raya for a resizing (haven't tried that before ) and buy a new wrist pin.
Life is good
Lille-bror is offline
Old 06-16-2013 | 06:51 AM
  #5692
theerm's Avatar
Has any one used a novarossi 51019 pipe and how do they compare to 9886 , 9901. They are not homologated and are 2 chamber. Are they just to noisy or are they no good.
Any body know ??
Cheers
theerm is offline
Old 06-16-2013 | 11:56 AM
  #5693
micke_b's Avatar
Anyone got a pipe suggestion for the KEEP-OFF 7XL in a buggy. I'd really love a pipe with a good sound. :-D
micke_b is offline
Old 06-16-2013 | 05:58 PM
  #5694
Jamison R's Avatar
R/C Tech Elite Member
What motor and pipe was Drake running to get 12 minutes plus at the nats?
Jamison R is offline
Old 06-16-2013 | 06:19 PM
  #5695
hookem34's Avatar
From what I could see in the pits, he was running the Keep Off 4 with 9901/41021 combo. I spent a lot of time watching him run this weekend and its my belief that his throttle finger is his biggest weapon. Super silky all around the track. Rolls on the throttle instead of jabbing it. He also has that baby leaned out pretty far. His needles are buried in the housing.
Edit: He was running the Worlds edition BTT.
hookem34 is offline
Old 06-16-2013 | 06:51 PM
  #5696
Drake & Nova National Champs
desotoracing is offline
Old 06-16-2013 | 06:53 PM
  #5697
Winning motor close up
Old 06-16-2013 | 08:48 PM
  #5698
CaptainHowdyt13's Avatar
Anyone have any experience/issue running a plus 4 btt in a truggy?
CaptainHowdyt13 is offline
Old 06-17-2013 | 03:27 AM
  #5699
dmartin's Avatar
It does ok but BTT has a smooth powerband and reduced low-end power because it is designed to be ran in a buggy. The best .21 in the Novarossi lineup for truggy is the Bonito. If you want to run a 4-port Novarossi in your truggy get the Plus-4 C Team Edition engine. It is same internally as the BTT except it has different exhaust timing to get more torque.
dmartin is offline
Old 06-17-2013 | 05:29 AM
  #5700
I hear ya. I have two brand new btt's and I guess I can just set the truggy up to work with it. I have a 2096 and 9901, and im being told to put the 9901 on the truggy for a little more bottom end snap. I can prob experiment with clutch springs too.
