NOVAROSSI Engine thread....
#2941
Has anyone found their BTTs running well over 300 deg? my engine wont run rt unless its around 310 deg.. its puffs out a bunch of smoke on the initial throttle pull and then i still seem smoke as its running down the straight. but yet if i lean out the bottom it runs on and if I richen it on the hsn no more then an hr or 2 it sounds like its drowning in fuel..
i use the 6.5 insert and power masters fuel in a serpent. is this fuel any good?
#2944
#2946
#2947
My Plus-4btts pretty much runs all the time at 260 and I feel like their is for sure more tune left in it. I was well more than 4.5t out on the LSN and still running 245 - 260. I do not doubt 290 to get optimum power for sure!!!!!
#2948
Hey all,
Just a quickie really,
Running a nova plus 4 btt in a MP9, using a 9901 pipe and 41021 header with a c6tg plug jvd clutch and 13t bell.
My endpoints are set and the carb doesnt fully open 6.5m venturi running 25% fuel.
Now my query, I have the idle gap set a 0.6m so thats good.
At the weekend is was hot and my engine wouldn't settle nicely on a idle no matter what i did went rich LSN then Leaner LSN no change richened out the top and repeated etc...
It ran but wasn't purring, also after 7.5mins i was on vapour! Now the engine is around 22 tanks old now. Always preheat before starting too.
I tried the base settings that i got off here and that was way too lean was running on just on the box so just some points to clarify -
Base settings for the engine?
what sort of tune are people putting on these I'm not an expert at tuning but I've got a rough idea which is why sunday was so strange?
my HSN is 3.75 out
LSN is 5 1/2 out..
my HSN is 3.75 out
LSN is 5 1/2 out..
no newer novarossi i have encountered has liked to be 5.5 turns out on lsn and have an "in balance" carb
#2949
Hey all,
my HSN is 3.75 out
LSN is 5 1/2 out..
my HSN is 3.75 out
LSN is 5 1/2 out..
#2951
#2952
352Likes
Canadian Team Blend eh !!!! Bacon and maple syrup flavored !!!!
