Like Tree352Likes
NOVAROSSI Engine thread....
Old 08-29-2019 | 08:52 AM
  #10426
Cain's Avatar
Tech Legend
Originally Posted by roblupo
plug all the holes on the pipe using zip ties. Fill it with water and then put in the freezer and check on it every four hours or so. Will take about a good 8 hours to push them out, however if you leave it in there to long you could mess up the inside of the pipe. Good thing about Nova pipes is that you want have to give up a leg to get a new one like OS pipes.
when you say plug the holes with zip ties, do you mean like zip tie some fuel tubing shut or something?
Originally Posted by Roelof
If you plug all the holes, how to fill it with water?
I think he means fill with water then plug the holes.
Will give this a look.
Cain is offline
Old 08-29-2019 | 09:23 AM
  #10427
HaulinBass's Avatar
I have my doubts on having the dents pop out of one of the nova SS pipes with ice.
HaulinBass is offline
Old 08-29-2019 | 10:33 AM
  #10428
Cain's Avatar
Tech Legend
are there any other pipes that have like a brace for what I think is called the "stinger" that would be recommended to give a look? seen some like a certain dynamite pipe that has a brace from the main pipe to the "stinger", basically that is where I got a bit of a dent going on.
Using a Paloma .21 limited gold head here in nitro buggy
Cain is offline
Old 08-29-2019 | 11:20 AM
  #10429
Chad Millikan's Avatar
The dynamite 086 is a good pipe that has what you're looking for.
Cain likes this.
Chad Millikan is offline
Old 08-29-2019 | 11:52 AM
  #10430
Cain's Avatar
Tech Legend
what about the 053 one?
Cain is offline
Old 08-29-2019 | 03:07 PM
  #10431
Oy will work, I've just always heard of the 086 with the novarossi engines. I personally havent heard of anyone using the 053.
Cain likes this.
Old 08-29-2019 | 05:09 PM
  #10432
fiveoboy01's Avatar
Originally Posted by JerseyGTS
Not sure if I should just pile on
to this thread...new nova p5, so much pinch i cant get the starter box to turn it over...heating it up with a heat gun and reading 200 degrees or so near the plug, will check battery on box, is this common with nova motors? Maybe heat more or perhaps I'm just getting a false reading near the surface but block isn't warm enough?I've had cheap motors before this and too much pinch was never a problem lol. Any help appreciated.
I've broken in three P5s in the last few months, and when new they will occasionally get stuck on the pinch early in the break in process, even with sufficient heat - to the point where a starter box will just smoke the wheel on the engine flywheel.
A screwdriver to pry the flywheel over is all that's needed. As the engine breaks in, getting stuck on the pinch goes away.
Cain likes this.
fiveoboy01 is offline
Old 08-30-2019 | 07:53 AM
  #10433
I do not understand why people have such a hard time breaking in these engines. They seem tight, but they’re nowhere near as tight as they were 20 years ago. If the top end is properly (keyword: properly) preheated and you actually run the engine, it will loosen up rather quickly. You have to actually run the engine to get it to break in and loosen up. If you shut it down every 5 minutes and let it cool down a bunch, you’re just adding more headache than needed and making the process take a lot longer than necessary. Of course my method will be contradicted because I’m not a bandwagon rider, but after several hundred engines of every construction method ever used, there’s very little difference in how it needs to be done. Fear and paranoia make the process far more complicated than it needs to be.
If the piston is getting stuck in the pinch, the top of the engine is not hot enough, period. I don’t care if the heatsink is 200F, that isn’t what needs to be heated sufficiently. The top of the crankcase below the heatsink is what matters. If this area is heated to 200-220F, I highly doubt your going to have sticking problems.
daveflyr likes this.
RCTecher12 is offline
Old 08-30-2019 | 07:57 AM
  #10434
As the pinch goes (wears) away, so does a bit of its power potential. Remember, an engine at operating temp does not have any pinch due to the brass liner expanding at the top. Just think - no pinch when cold means (hypothetically) a perfect seal when cold and a less than perfect seal when hot due to the brass liner expanding more than the piston.
Old 08-30-2019 | 04:05 PM
  #10435
fiveoboy01's Avatar
I didn't say anything about no pinch when cold. I meant when preheated. A broken in engine will always start and run easier than one that is brand new, even if the preheat temp is the same. I don't agree that there's no pinch when the engine is at operating temp. Less, yes. None, no.
Old 08-30-2019 | 04:29 PM
  #10436
Then you don’t understand the metallurgy of your engine as well as you think you do. Everyone learns at a different pace. Some eventually get it, some don’t.
Old 08-30-2019 | 04:41 PM
  #10437
fiveoboy01's Avatar
Thanks, I never claimed I had a clear understanding of that. Just relaying my experiences, but don't let that stop you from proclaiming your genius.
Old 08-30-2019 | 08:49 PM
  #10438
If you don’t understand the metallurgy and how it actually works, how in the hell can you say there is still pinch at operating temp?
Old 08-31-2019 | 12:59 AM
  #10439
Roelof's Avatar
When pre-heating an engine to the same temp as the operating temperature then you are compleetly wrong of the temperature inside the engine.
Arround the combustion chamber the temps can go up to over 1000 degrees celcius when running and then there is cooling from the fuel and transferring the heat to the outside through crankcase and head all with a resistance.
No professor can calculate it correctly, all choices of the sleeve taper angle, materials sleeve and piston and the matchin cooling head are made by just trying.
Pedro Jesus and Razenzo like this.
Roelof is offline
Old 09-13-2019 | 12:34 PM
  #10440
Default Mephisto
Can someone give a review on the Mephisto?
Botom, top and mileg
Talsys is offline
