Like Tree352Likes
NOVAROSSI Engine thread....
Old 09-30-2017 | 06:12 AM
  #9706
Originally Posted by joeh5088
Anyone ever had the low speed needle move/turn or change setting while driving their car?Can this happen due to vibration?
I had this happen on a Mach 427 engine some years ago - but it was the main needle that was moving on its own. The o-rings had shrunk and hardened with time. New o-rings cured the trouble. I wouldn't doubt the same could happen to the idle mixture needle. Worth looking into IMO.
RCTecher12 is offline
Old 10-04-2017 | 07:18 PM
  #9707
houston's Avatar
yup
orings dry out
houston is offline
Old 10-11-2017 | 05:16 AM
  #9708
cczjordan's Avatar
Mito 7 is a great buggy engine, just a bit thirsty on juice. Anyone has mito 4 (both) can give their opinions?
cczjordan is offline
Old 10-12-2017 | 05:53 AM
  #9709
NOVAROSSI MANTRA - INSIDE
One thing I had already noticed, the Mantra does not share the block and the carburetor as from MITO 4.
It could be square, but have the same block and carburetor from MITO 4.
Novarossi Mantra: Inside - ModellismoRC.net
Pedro Jesus is offline
Old 10-12-2017 | 05:54 AM
  #9710
Old 10-14-2017 | 07:53 AM
  #9711
zonda's Avatar
Default Tame a P5XLT
What do you guys do to tame your P5xlt motors?
Over half a gallon through this engine so not yet fully run in. With a 2096 SS pipe this thing is insane 😂😂 Low & mid range is mental plus decent top end with lots of smoke still. Using the 7.5 venturi, 1.1 springs I think.
Any tips to make smoooother? I want to start practicing !
zonda is offline
Old 10-14-2017 | 09:52 AM
  #9712
slodsm's Avatar
R/C Tech Elite Member
What manifold are you using, the 2096/41021 is pretty smooth to me.
slodsm is offline
Old 10-14-2017 | 11:13 AM
  #9713
houston's Avatar
Get rid of the 1.1mm springs for starters ....lol
Sean Pryce likes this.
houston is offline
Old 10-14-2017 | 04:56 PM
  #9714
slodsm's Avatar
That too lol, I use 2 .9's and 2 1.0's with all aluminum shoes.
slodsm is offline
Old 10-15-2017 | 07:24 AM
  #9715
zonda's Avatar
Using the 2096/41029 combo... will try smaller clutch springs
zonda is offline
Old 10-15-2017 | 07:53 AM
  #9716
dan_vector's Avatar
I'd also be using 6.5mm venturi and the 9901/41021 pipe/manifold on that engine in a buggy.
dan_vector is offline
Old 10-15-2017 | 12:42 PM
  #9717
zonda's Avatar
Thanks Dan, I'll order the 9901 pipe this weekend. Heard it's smoother with better run times. My current setup absolutely rips ☺
zonda is offline
Old 10-15-2017 | 03:44 PM
  #9718
Why would you order a pipe that will add more bottom and lose top? The 2096 is the right pipe. Maybe Monty can add some info. I have a 9886 on mine but it is a older pipe with a square header.
Chris Reilly is offline
Old 10-16-2017 | 07:42 AM
  #9719
cczjordan's Avatar
41033 manifold, if need to tame it again, use steel flywheel but cheapest solution is change softer spring or carbon shoes
Old 10-16-2017 | 05:11 PM
  #9720
I recently got a Virtus .21 offroad engine and today I finished the first part of the break in, but before I take it to the track can anyone recomend me a pipe and header for this engine.
My local track is a medium/small track and it is a fast track so run time is key to success.
Also if I am not mistaken it is also advise to remove one of head shims once break in is done.
Thanks for all the help.
moisesing is offline
