Like Tree352Likes
NOVAROSSI Engine thread....
Old 04-10-2019 | 12:36 PM
  #10231
PinoyCali's Avatar
hello.
Any one tried the new P5XLT 2019? How is it?
PinoyCali is offline
Old 04-10-2019 | 02:48 PM
  #10232
Jomo918's Avatar
Honestly most nova 21s are more then capable of moving a truggy very well... my favorite for truggy is any of the P5 variants, like the Elite 5 or P5XLT.... I'm currently using a blue top nova paloma.
Jomo918 is offline
Old 04-10-2019 | 03:08 PM
  #10233
Originally Posted by houston
need shaft extender washer .....
or too many washers to start with
InTheZoneAC is offline
Old 04-10-2019 | 06:11 PM
  #10234
houston's Avatar
i have personally installed many buku clutch assemblies and novarossi made engines into losi , tekno and serpent cars ...... it was necessary to install clutch so it needed shaft extender washer .....
savage24x likes this.
houston is offline
Old 04-11-2019 | 10:35 AM
  #10235
savage24x's Avatar
Yep, my serpent stuff definitely needs the losi extension washer. Kind of annoying.
savage24x is offline
Old 04-21-2019 | 10:24 PM
  #10236
I can’t post pictures until I have made 10 posts so excuse my lack of photos.
I just acquired a novarossi motor with my buggy and the guy wasn’t sure which model it was. It has buggy engraved on the head and plus on the side of the block. I know it’s hard to identify a motor without many photos - but anyone have any idea?
Cheers.
harawong is offline
Old 04-22-2019 | 01:41 AM
  #10237
Cheers.
21+4
Soyer is offline
Old 04-22-2019 | 06:37 AM
  #10238
Chad Millikan's Avatar
Another route of finding the model would be going to Novarossi website and looking at all of the engines and see which best looks like yours. They have all of the discontinued engines also. Good luck .
Chad Millikan is offline
Old 04-22-2019 | 11:45 AM
  #10239
Cheers.
Originally Posted by Soyer
21+4
What Soyer said.
PLUS 21-4 BUGGY - NOVAROSSI WORLD
Did it come with the hair wrapped around the carb? lol
sebtarta is offline
Old 04-23-2019 | 05:24 AM
  #10240
Lol nah no hair. Is there still rebuild kits available for this motor? Will the 21+4btt kit fit - part number NVR08502.
harawong is offline
Old 04-23-2019 | 06:37 AM
  #10241
Looking at the exploded view from the engine's web page, it is the same part number as the one you mentioned.
http://www.novarossi.it/2012/images/...PLUS4BUGGY.pdf
Novarossi Direct has the kit - 08502
sebtarta is offline
Old 04-23-2019 | 02:16 PM
  #10242
One question I do not know if I can answer.
But here goes, why does Novarossi still use plastic and metal in its carburetors in OFF-ROAD?
Since other brands use the carburetor all in aluminum.
Thank you
Pedro Jesus is offline
Old 04-23-2019 | 02:42 PM
  #10243
Suspended
Thank you
It's not so much why nova still has plastic... its more the fact, everyone else cannot get the plastic and alloy to seal properly... alloy heats up more thats why o.s use the insulation sleeve.
novarossi got them to seal properly so they were rewarded with a less heat carb thats cheaper to produce. win win.
iplaygames is offline
Old 04-23-2019 | 09:03 PM
  #10244
kgombe's Avatar
while that is true, why do they use aluminum carbs on their on road engines?
kgombe is offline
Old 04-24-2019 | 02:41 AM
  #10245
Suspended
to be honest i have no idea. must be some idea behind it, Drake told me the above reason.. might be one of those strange mysteries like why onroad engines use a metal shielded bearing "that must leak so bad its untunable" just like all the people who say.. a leaky front bearing is bad.. not quite how that works as the front isnt air tight, and alot of the times the bearing is worn, dirt has entered and worn the crankshaft where it seals and thats where problems start...
