Like Tree352Likes
NOVAROSSI Engine thread....
Old 05-07-2012 | 09:23 AM
  #2731
token's Avatar
Ran the P5 in Truggy and Buggy this weekend.
9901/021 in truck
9886/021 in buggy
I was very surprised with this engine on a large out door track with big jumps. This engine held its own against some top engines. I did run on the lean side. Getting 9 mins in truck and 10 in buggy at 5000 feet up. I am very happy with these engines.
token is offline
Old 05-07-2012 | 04:33 PM
  #2732
savannahmick's Avatar
Originally Posted by houston
the oils have gummed up/shellac'd/varnished the piston/sleeve , i am 100% sure of it , just run it cause if you clean it off the piston/sleeve fit will be very loose
I decided to open it up and check out the internals and there is no build-up on the sleeve or piston other than a little on top of piston. The crank is pretty clean also but the bearings have a little carbon on the races. Anyway my Nitrotec was at 2 gallons when it dropped pinch and I think I have been real easy on the btta since our track (Phil Hurd)has alot of tight turns and controlled throttle jumps also only one straight thats not that long. Like I said I ALWAYS preheat and never run it real rich. Used 2% Bryons lube booster for first gallon of VP 30/9 so I hope thats the reason it still has pinch when cold. My needles are flush hsn/ 1/4 turn below flush lsn with 7mm insert does that sound about right? Thanks Again!
savannahmick is offline
Old 05-07-2012 | 05:50 PM
  #2733
houston's Avatar
sounds pretty close on the needles
the buildup is totally unnoticeable , it will feeel kinda plasticlike actually
good job on the lube booster for break in!! castor oil is a must for break ins
houston is offline
Old 05-07-2012 | 10:20 PM
  #2734
Originally Posted by revo61
OS plugs will work but you will never be able to go back to nova plugs. They are not the best choice. I would use Odonnell or Novarossi.
DOes the 97t work fine in them? Its a Clockwork NOva P5.
thorns is offline
Old 05-07-2012 | 10:43 PM
  #2735
hambone's Avatar
97t is way too hot for a clocked P5. Use what Neal suggests. Werks #6 or nova 6. Don't skimp on glow plugs.
hambone is offline
Old 05-08-2012 | 12:34 AM
  #2736
Roger that!
thorns is offline
Old 05-08-2012 | 06:50 AM
  #2737
those looking for the new off road carburetor I have them in stock now...
http://www.absolutehobbyz.com/produc...ducts_id=10167
insert it comes with is 5.4mm
Chad Phillips is offline
Old 05-08-2012 | 07:00 AM
  #2738
Maximo's Avatar
OS plugs are a no go.......coild too thin
use
OD 99 (not 97)
Nova #6
Werks #6
Maximo is offline
Old 05-08-2012 | 10:38 AM
  #2739
merdith6's Avatar
Default Finally
use
OD 99 (not 97)
Nova #6
Werks #6
I completely agree Maximo. the 99t, and Nova c6tgc are my favorite plugs, I have not tried the werks..
Those 99t's are getting scarce....I see guys all the time running too hot a plug and burning them up and I tell them get a cooler plg, they rarely listen because so many think hotter is better. They can keep on flaming out for all i care....
merdith6 is offline
Old 05-08-2012 | 02:03 PM
  #2740
bigjayjay1's Avatar
What's the ADVANCES to this new carb will this carb be included in all new engines like the roma
bigjayjay1 is offline
Old 05-08-2012 | 03:35 PM
  #2741
beidle99's Avatar
My unrstanding is that its biggest improvement will be fuel economy. But with a 5.4 venturi I would think the tuning window will be pretty small. Maybe Monty can chime in or some one that has used it. I would think that the neddles would have to be a very fine thread
beidle99 is offline
Old 05-08-2012 | 04:02 PM
  #2742
kgombe's Avatar
it also a 7mm carb instead of a standard 9mm carb... so I'm guessing the 7mm port goes all the way through instead of putting 7mm Venturi that eventually has a 9mm opening in the bottom... which will slow air pressure somewhat.... i'll stop there.. LOL
kgombe is offline
Old 05-08-2012 | 05:14 PM
  #2743
air8's Avatar
I always thought the more air and fuel you can get in, the more power you can get out. So I'm not understanding the reduction in throat size. But that's why I'm not and engine designer either. LOL.
air8 is offline
Old 05-08-2012 | 05:18 PM
  #2744
houston's Avatar
a properly jetted engine will maximize power and fuel consumption
its not always about " the most power" Chris
houston is offline
Old 05-08-2012 | 06:28 PM
  #2745
kgombe's Avatar
i guess but when you consider a 9mm carb with a 7mm reducer in it.. it makes you wonder she even make it 9mm when you sell it with a 6.5 install...
kgombe is offline
