Like Tree352Likes
NOVAROSSI Engine thread....
Old 04-17-2012 | 12:08 PM
  #2581
sinisterRC's Avatar
Originally Posted by mjealey
Novarossi P5xlt from Clockwork Racing, OFNA 086 or Nova 9886 pipe to go with it. If you are wanting to save some money you can get bone stock P5 and OFNA pipe for under $300. P5 from Clockwork yields much longer run time and better powerband though. I am really diggin the OFNA 086 pipe and hearder, and and for $50 it is a steal!!! Runs very well in my Mugen with over 10 minute run time in my MBX6t!
Thanks for the help, I'm looking into the P5 right now.
sinisterRC is offline
Old 04-17-2012 | 12:28 PM
  #2582
merdith6's Avatar
Default Well
Originally Posted by Luckylouse
Last of the pics... sorry for the abundance of shots...
Buku Clutch
Attachment 908877
Crank
Attachment 908876
Clutch Bell
Attachment 908878
Based on the pic of the clutch, not that i have one, butit looks like the material is added to a regular clutch shoe, and so it may sit a bit closer to the bell and require more tension on the spring to keep the engine from being dragged down by the clutch at idle, it's probably stalling when you let off the throttle, not when you get on power, it's not about clearing out as muchas it is about the drag at idle....I would make the springs tighter. that should solve your problem, and readjust the idle and low end.....
merdith6 is offline
Old 04-17-2012 | 12:42 PM
  #2583
PERROTTO's Avatar
One more thought on the flame out.. I'm running the Buku Clutch with Ceramic pads. I just inspected the Clutch Bell and there is already a good grove in it. This is after about 1/2 Gallon. The Springs are set at stock meaning they are set very soft. Could the Flame out be caused by early engagement of the clutch on load? The Track was mostly clay. I would consider VERY high traction and I was using New Super Soft Gridirons that were hooking up like mad. Sorry for the rookie type questions but I don't want to leave any rock unturned on this one..
A friend of mine running Mugen recently switch to the buku clutch and he was having problems flaming out after the clutch install. This was at the Nitro Challenge a couple months ago and Monty was in attendance so he there right away to help. He found out he had some clearance issue between the buku flywheel and the brake pads which was causing the engine to stall when they made contact. From what ive heard about the buku clutch, you are supposed to tighten the clutch after the first few runs because the heat will weaken the springs slightly. the picture of your clutch doesnt really indicate that it was rubbing on anything but its just something to keep in mind.... The engine internals look very good as they should with less than 2 gallons through it and the seal on the top of the piston looks immaculate.
How stable is the idle?
PERROTTO is offline
Old 04-17-2012 | 01:06 PM
  #2584
mjealey's Avatar
I literally has the same thing this past weekend except with a Werks clutch in My MBX6t. I put the motor in the truggy for the first time. Only thing different from previous runs in the buggy was the pipe and clutch. In buggy I was running 9886 and stock Mugen clutch, truggy I run OFNA 086 and tried Werks "light" clutch. Motor would die with no rhyme or reason in the truggy. Could not figure it out at all. Took clutch off, shimmed correctly, bearings like brand new. So I threw on a spare Mugen clutch and the problem was solved. Ran for 45 minutes straight and ran much better for some reason on stock clutch and did not touch anything else. Do not know why but the CRE P5 did not like the Werks clutch at all!!!!!! Sounds like you might be suffering from the same symptom as I was.
mjealey is offline
Old 04-17-2012 | 01:32 PM
  #2585
That the thing... I was so frustrated this weekend with the idle that I spent 30mins prior to my race tuning it. The idle was perfect.. and some of the more experienced A drivers agreed... Although they were OS users. I"m going to check the springs and figure out where we stand.
Luckylouse is offline
Old 04-17-2012 | 01:35 PM
  #2586
Lol... Funny thing is my stock 4btt was sitting in my tool box ready to go with a stock clutch... I should have gone with that one. You live you learn... Stay tuned for my video as I try to get my beast up and running properly... I will give the BUKU 1 more try.
Old 04-17-2012 | 01:43 PM
  #2587
mjealey's Avatar
I do not know why, and not to bash, but I have tried all of the aftermarket clutches and I keep going back to the stock Mugen.....Most reliable and feels really good. Nice and simple and eliminate any problem in a race!!!!!
mjealey is offline
Old 04-17-2012 | 02:13 PM
  #2588
PERROTTO's Avatar
Agreed. The Mugen clutch never gave me any issues except the 1.0 springs suck and break every once in while when new....Have you tried this one? I am in love with this clutch.
PERROTTO is offline
Old 04-17-2012 | 02:38 PM
  #2589
merdith6's Avatar
Default Yep
The stock Mugen clutch with the hard Mugen shoes and 1.0 springs is the best clutch on the market. One less gadget to fail....
merdith6 is offline
Old 04-17-2012 | 02:39 PM
  #2590
Guys,
A very friendly gentleman from BUKU contacted me and explained what likely happened. After taking a close look at my Clutch Bell I didn't shim it properly and the clutch shoes touched the face of the clutch bell. I didn't notice it right away but there is a grove at the face of the CB and the shoes also show evidence of this. So there you go... as is VERY common in this hobby... USER ERROR! lol
Thanks to BUKU and Clockworks for your help and customer satisfaction! Unbelievable customer service... Now let me get this car back together... Video will come shortly.. Also... I'll post pictures of the BUKU diagnostics... Brian was BANG on!
Old 04-17-2012 | 03:16 PM
  #2591
Here's the problem... Thanks to Brian from BUKU to point this out... Notice the White line indicating the wearing and of the front face of the clutch bell. When landing hard forward over the triple the clutch shoes wandered ever so slightly with the play in the clutch bell and stalled the engine.
This was due to poor shimming... sometimes it's just back to the basics!
Old 04-17-2012 | 04:27 PM
  #2592
It doesn't take much to stop an engine. You see people do it with their thumbs!
Semple is offline
Old 04-17-2012 | 04:35 PM
  #2593
houston's Avatar
Properly setup aftermarket clutches work very well and can compliment your novarossi engine nicely
Hope you get it all figured out luckylouse , lmk if i can ever help ya out brotha
houston is offline
Old 04-17-2012 | 05:34 PM
  #2594
Thanks Houston... I really appreciate it!!! Brian Made mention that you are a big supporter of the BUKU too.... So that makes 2 Novarossi Guru's that like the Buku... sounds good enough to me.
Old 04-17-2012 | 05:35 PM
  #2595
Hey John... Next time you go to Hardcore send me a PM if you want to play around with this set-up I have. Are you running Nova? If not you must be thinking about if you're speaking up in this thread.
