Like Tree352Likes
NOVAROSSI Engine thread....
Old 05-18-2011 | 07:39 AM
  #1081
ben73's Avatar
Originally Posted by PowerHouse
The 28028 is thicker and uses the orange outer oring to keep the dirt and grit from getting into the sleeve/case lange that can create removal issues. You can use the 28028 on the older engines, the cooling head just sticks up higher in the vehicle but you can't use the 28002 on the team head as it will interfere with the case unless you machine down the cooling fins on the upper case to allow clearance.
Ok I understand the size issues but the question I had was is the 28028 a turbo button for the team engine?
Can I use my turbo plugs in it like I do with the 28002?
I cant find anywhere where it lists what it is 100%.
gee I wish Novarossi just shipped all engines with turbo buttons!
ben73 is offline
Old 05-18-2011 | 07:51 AM
  #1082
houston's Avatar
They all use turbo now
Yes 28028 is turbo
houston is offline
Old 05-18-2011 | 05:15 PM
  #1083
ben73's Avatar
Yes 28028 is turbo
excellent!
thanks. that save some $$$ buying a new button
ben73 is offline
Old 05-19-2011 | 11:14 AM
  #1084
houston's Avatar
excellent!
Good deal, hopefully your engine setup brings you many smiles
houston is offline
Old 05-19-2011 | 03:07 PM
  #1085
PinoyCali's Avatar
Default Shim
Hello...
Just recieved my bonito is the shim set up for 30% nitro?
Thanks..
PinoyCali is offline
Old 05-19-2011 | 03:08 PM
  #1086
hi guys ....
i have a plus 4 team edition... the engines runsvery good but not have that loe end that i will want... I race with the short header... also have the long header... the track is very tecnical... no large sections... I know that putting the long header will give the low end that I want the question is with fuel... does anyone compare fuel mileage with this two headers?
thanks
segreda is offline
Old 05-19-2011 | 03:37 PM
  #1087
houston's Avatar
Originally Posted by PinoyCali
Hello...
Thanks..
Yes and I would recommend reshimming to .70mm or .65mm after a gallon, do not go any lower than .60mm
Originally Posted by segreda
hi guys ....
thanks
What's your setup? I would need to know which pipe, plug, clutch, gear ratio, etc. before making any suggestions
houston is offline
Old 05-19-2011 | 03:44 PM
  #1088
PinoyCali's Avatar
Thank you ... Houston
Old 05-19-2011 | 03:49 PM
  #1089
houston's Avatar
No prob bro
houston is offline
Old 05-19-2011 | 03:52 PM
  #1090
thank for the reply houston
here is my car
durango dnx408
stock gear 13 cluthbell 48 spur
pipe... 9901 with the nova short header
cltuch ascendancy efortless 1.0 all around
plug odonell 97
here is very high humidity... temps around 250
run time aroun 10:30
the track is very tight... but with vey little space to come over the jumps
i have also the nova long header
segreda is offline
Old 05-19-2011 | 04:22 PM
  #1091
houston's Avatar
here is my car
durango dnx408
plug odonell 97
Is the clutch new?
That design of clutch slips for quite a while until the shoes/bell get wore in together
did you already check to make sure your clutch isn't slipping?
That setup you have going should have alot of "pop"
houston is offline
Old 05-19-2011 | 04:35 PM
  #1092
never tought of it... YES IT S NEW!!!!!!!!!!!!
just put it for practice past saturday ( pracrtice like 1/2 gallon)
just open the cltuch to inspect and yes its very dark ( clutch bell material) will do the clutch maintenace and hit the track this saturday...
sorry to bother again ( how much time aprox will i have to run it until it doesn t slip more???)
will put 2 1.1 to get a stiffer clutch setup and if that doesn t work... will try the nova long header ( saving this change for last)
thanks vry much
appreciated houston
segreda is offline
Old 05-19-2011 | 07:51 PM
  #1093
houston's Avatar
thanks vry much
appreciated houston
first off this should be discussed in a clutch forum but
did you use a new clutch bell?
did you scuff the clutch bell before installing ?
did you clean the grease out of the bearings ?
did you break in the clutch by giving it copious amounts of throttle then putting a load on it by forcing it to the ground ?
is your flywheel nut tight and not slipping?
go through that checklist then get back to me
hope this helps
houston is offline
Old 05-19-2011 | 09:58 PM
  #1094
ben73's Avatar
Hey Houston
question for you.
I have generally got 11:20 runtime from my plus 21-4 engines but over the past couple of meetings my economy has gone out the window. I am down to 9 min.
Cant seem to find the issue, same clutch as before, 9901 same pipe. fuel still 25%, shimming the same.
I am even getting about 6 ml more from my tank now after a fuel filter and some tank mods. tank capacity is 124ml now.
Ive put new plug in leaned the top end a few hours but with no large change to efficiency. I checked my carb settings against a post youput up a few days ago and they were within a qtr turn.
idle .6mm lsn was bang on and hsn was a qtr turn leaner than you posted.
any ideas or places I should look at? or should I just keep leaning it out?
I have 2 engines that are both delivering similar runtime. The older one has 5 gallons on it and I have just replaced rod, pin and new nova ceramics bearings.
thanks
Ben
ben73 is offline
Old 05-19-2011 | 10:22 PM
  #1095
houston's Avatar
Hey Houston
question for you.
thanks
Ben
Has there been a major track change at you're local track recently?
Major weather changes? Hotter air needs leaner needle settings and cooler plugs
Drivetrain on car free?
houston is offline
