Like Tree352Likes
NOVAROSSI Engine thread....
Old 03-23-2019 | 07:47 AM
  #10216
I misspoke. 0.04mm is perfect.
RCTecher12 is offline
Old 03-23-2019 | 08:36 AM
  #10217
kgombe's Avatar
Originally Posted by SlowLST2
That’s still a lot/too much IMO. .04mm is almost .016”. .001” endplay is as tight as you want, maybe .003-.004” on the high side.
maybe read first before trying to show off your math skills.. 😅
he said .04mm not .4mm
.04mm is .001in
kgombe is offline
Old 03-23-2019 | 09:32 AM
  #10218
houston's Avatar
Originally Posted by Cardiak
I'm replacing my clutch bell but when I go to tighten the retaining screw and washer, the clutch bell binds. I have 4 washers behind the rear clutch be bearing.
need shaft extender washer .....
houston is offline
Old 03-23-2019 | 10:28 AM
  #10219
Yep. I was using one but I figured out the problem. I was thinking that I had put 2.4mm worth of washers on the extension. Everything is good now.
Chad Millikan likes this.
Cardiak is offline
Old 03-23-2019 | 12:31 PM
  #10220
Originally Posted by kgombe
maybe read first before trying to show off your math skills.. ��
.04mm is .001in
Initially they said .94, but corrected it in a subsequent post... I don’t study the metric system, so I use those stupid and rarely accurate internet converters. Oddly enough, I suspected another conversion I did didn’t make much sense... So only after using a different formula did I find the mistake and the correct conversion result. I’ll edit my post to read correctly.
Old 03-23-2019 | 12:37 PM
  #10221
Yup. Comes in a clutch shim kit usually.
Old 03-25-2019 | 05:53 PM
  #10222
HaulinBass's Avatar
anyone ever measure up the bore and stroke on the mantra? not just what nova states but the actual numbers. Unless he was getting some weird numbers its not a square stroke motor or a .21, its 16.46 bore with a 16.8 stroke closer to a .23 than a .21.
HaulinBass is offline
Old 03-26-2019 | 02:00 AM
  #10223
[QUOTE = HaulinBass; 15420134] alguém já mediu o furo e o derrame no mantra? năo apenas o que a nova diz, mas os números reais. A menos que ele estava recebendo alguns números estranhos năo é um motor de acidente vascular cerebral quadrado ou um 0,21, sua 16,46 furo com um golpe 16.8 mais perto de uma .23 que um .21. [/ QUOTE]
Its 16.42mm not 16.46mm
Pedro Jesus is offline
Old 03-26-2019 | 06:59 AM
  #10224
HaulinBass's Avatar
is that measured or what novarossi states? because the guy that measured mine gave me those numbers and its a guy whos opinion is fairly well trusted
Old 03-26-2019 | 02:27 PM
  #10225
My brother,
I have two Novarossi Mantra’s. Ones a factory Nova engine and ones a Hobby shop “deal” I got before I picked up a novarossi power supply.
The Factory mantra measures a tad different to what your stating above but is still close enough to a .23.
However the one from the hobby shop which is a “buy off the shelf version” measures exactly what your stating.
91junior is offline
Old 03-26-2019 | 02:32 PM
  #10226
A 16.46mm bore and 16.8mm stroke gives a swept displacement of .218 cubic inches.
Old 03-27-2019 | 01:14 PM
  #10227
MANTRA - NOVAROSSI WORLD
Old 03-27-2019 | 04:14 PM
  #10228
Originally Posted by Pedro Jesus
According to Nova, it’s a square stroke engine with a 16.42mm bore and stroke giving a swept volume of .212 cubic inches.
Old 04-10-2019 | 09:56 AM
  #10229
savage24x's Avatar
What .21 engine are people recommending for truggy nowadays that the rex paloma limited isn't being sold?
savage24x is offline
Old 04-10-2019 | 12:35 PM
  #10230
A Roma .25 is what I have seen many people run here.
I have also see some run regular .21, Elite 5 and Rolling.
savage24x likes this.
sebtarta is offline
