NOVAROSSI Engine thread....
As far as the front bearing failure... I'm pretty sure your flywheel is rubbing against it after trimming your collet. I suggest using a new (unmodified) collet and use an extend (stepped) front washer to get the proper clutch bell shimmimg.
That double seal bearing is the best one out there, I highly doubt the second seal let contaminants in. Just for peice of mind, I would take it apart and do a thorough inspection and clean. If everything looks good just replace the front bearing.
There are also shims you could buy. Just search on Amain for some 3x5x0.5 shims and use as many as you need before installing the Losi washer. They also come in different thicknesses.
I just wonder what you just send....
As you may know this is a forum where questions, answers and discussions are done in the open so everyone can enjoy the reading and step in.
If it was something personal or something commercial you do not want to show us, just do not make such posts so we (for sure I) do not get curious to know what you just have send. And to be honest, the receiver will know you did send him a PM by a notification on top of the page and if the settings are right, by email.....
track dependent and weather but generally 9-10:30 on the rolling
the p5 was still rich and a tick pinch yet but a solid 10 mins so far.. changed the header to a shorter one to try and get a tick more top end.. if the rain holds out I will know sat night on how it pulls.
From: a very small town in wisconsin that is in the middle of absolutely no where
Has anyone tried the .25 Roma Engine in a buggy? I'm curious of the runtime, venturi, temperature, pipe, and if the power is controllable. I understand this is a great truggy engine.
cheers! Novarossi for life!
Any tips on where to look to correct a flameout that happens say 10 minutes into a race?
We are thinking the glowplug may need to be replaced. Vehicle had at least half a tank of fuel, fired up quickly and temps were about 250 on a Paloma Limited .21
Been working well in general, just had that happen and probably cost me 3rd place . Hoping to get them next time
I've had certain Novas, like the Elite 5 and Elite 8 that just seem to run better on a c5tgc instead of a c6tgc for whatever reason. Seems to improve the idle and minimize the flameouts.
total noob here with nitro so can give that a look. Right now I have a whole bunch of oddonnell plugs that came brand new sealed that I have heard can work well too.
I was always told it's not good to go back and forth between brand of plugs. The pitch or bevel whatever you wanna call it is slightly different from brand to brand.
Try experimenting with plugs, between the 77t, 97t, c5tgc, or c6tgc I usually find one that hits the sweet spot.
352Likes
